leaking rear diff
Old Mar 28, 2006 | 07:18 PM
C5 RACNG's Avatar
C5 RACNG
Default leaking rear diff
I had my 04 at the dealer for the common rear differential leak last year after 3K. car has been garaged for the winter and noticed the same leak from the right side, so with 5K and dreadful of taking it back again to see if they can get right,
here we go again
here's an article on the problem from May 06 Corvette Fever
Old Mar 28, 2006 | 07:21 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Twice within 5K? I hope that things turn out better next go around, take it back!
Old Mar 28, 2006 | 07:43 PM
tiojames's Avatar
tiojames
Default diff leak
Took mine to the dealer at 9,000 miles. They are not a certified vette dealer(too small of an operation) and they knew nothing about the dreaded diff leak. Turned out to my advantage. The mechanic looked past the seal hoopla and found a casting hole in the cover plate. No charges and no leaks since.
Old Mar 28, 2006 | 08:59 PM
rrichar2591's Avatar
rrichar2591
It took me about 4 trips to get it all completly stopped. As long as it's under waranty, I would give them another shot.
Old Mar 29, 2006 | 06:50 AM
I know how you feel. Mine has been in the shop three times with a leaking differential seal. Last time was about two years ago and looks like they finally got it fixed.
Old Mar 29, 2006 | 07:27 AM
mike348's Avatar
mike348
My 04 started leaking at 5000. Dealer changed the left cover and seals.
no more further problems at 14000.
To leaking rear diff
