Oil life
Old Mar 28, 2006 | 10:41 PM
ConvertedWS9's Avatar
ConvertedWS9
Default Oil life
WTF!!!!! ok
So i bought my car 2 weeks ago.. The oil life was at 50% when I bought it and as of yesterday was as low as 48%. I decided to do an oil change. I bought some mobil 1 and ac/delco filter... Because of how steep my ramps are I took my car to walmart.. I gave them the oil and the filter... 5 mins later done.. I get back in my car and expect to see 100% and it's 38% Now I need an answer..
Thanks in advance..
David.
Old Mar 28, 2006 | 10:51 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Obviously - the oil life monitor was not reset. You can reset it yourself by turning the car on (not running ignition on) bringing up oil life on the DIC and hitting RESET. The system does not reset itself just because you changed the oil.....
Old Mar 28, 2006 | 10:58 PM
ConvertedWS9
THANK YOU!!! I tried reseting it while the car was on and it just wouldn't change... I do that in the morning.. Thanks again.
Old Mar 28, 2006 | 11:11 PM
Evil-Twin's Avatar
Evil-Twin
You can allow your oil life to get down to Zero,,,,,,
The oil life monitor is very smart when it comes to calculating when your oil needs to be changed....
Old Mar 28, 2006 | 11:29 PM
chocoholic's Avatar
chocoholic
You might want to start by reading your owner's manual. That way not only will you know how to reset your oil life monitor, you'll also know when you should be changing your oil as well as the learning about the usage of all the other ***** and buttons on the car.
If you didn't get the owner's manual, you can get one online at www.mygmlink.com
Old Mar 29, 2006 | 06:44 AM
It sounds like they just did not reset the oil life monitor on the car. Seems strange though that it dropped 10% points in a day (provided you really meant to say it was at 38% after the oil change).
Old Mar 29, 2006 | 06:49 AM
hardtop's Avatar
hardtop
By taking it to wally world, that is an automatic 10 point reduction
Old Mar 29, 2006 | 07:01 AM
Patman's Avatar
Patman
If you reset the monitor with the ignition on but the engine off, it will go back to 100% again.
Old Mar 29, 2006 | 07:52 AM
DeeGee's Avatar
DeeGee
WTF!!!!! ok
Thanks in advance..
David.
You can also reset the oil life by pumping the gas pedal 3 times - but not with the engine running.
Old Mar 29, 2006 | 10:01 AM
jrose7004's Avatar
jrose7004
I really thought that it was 100 points!
Old Mar 29, 2006 | 10:43 AM
Mark S.'s Avatar
Mark S.
The oil life monitor is only a guide...stick to the recommended oil change intervals (if you think the 15,000/1 yr is too extreme, then change it every 6 months or every 10K miles)...the other thing to keep in mind is that the oil monitor is unable to calculate (add % to your oil life) in the event you have to add oil. A lot of 2001 C5s have to add oil just after 5-600 miles...so the monitor is useless...use an interval that makes sense to you and your style of driving (but don't exceed one year)...
Old Mar 29, 2006 | 10:50 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
With ignition on before starting the car.
Old Mar 29, 2006 | 10:53 AM
bsmithC5/2004's Avatar
bsmithC5/2004
Old Mar 29, 2006 | 11:46 AM
VetteLag00's Avatar
VetteLag00
You may need to hold last pump for 5 to 10 seconds. For some reason when I try it from the DIC it just goes right back to were it was next time I start it so I use the pump the gas pedal method. When I first heard of it I thought people on here were kidding.
Old Mar 29, 2006 | 11:58 AM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
To Oil life
