Use it or lose it?
Old Mar 29, 2006 | 07:57 PM
MrLeadFoot's Avatar
MrLeadFoot
Originally Posted by AC54ME
Quick fix for that issue - get the brass gears
I didn't even get a brass gear when my driver's motor went bad. I just rotated the stock plastic gear 90 degrees to put the bad teeth in an "un-used" position, and reassembled the motor. I figured it was free, and if it happens again in 40K miles, I'll get another plastic gear.
For some reason, I'm scared that a brass gear might cause a complete failure if the worm gear jams. I'd rather have the plastic teeth "forgive" an operational error.
But, maybe I'm too ****, and I'm worrying for nothing, if headlight motors are cheap to begin with. Somehow I doubt that, because even floor mats cost twice is much for a vette than they do for other Chevys.
Old Mar 29, 2006 | 07:59 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Turned that annoying feature off the day I bought the car.
Old Mar 29, 2006 | 08:02 PM
spdislife's Avatar
spdislife
Never used it...and no plans to do so.
Old Mar 29, 2006 | 08:07 PM
mwagne16's Avatar
mwagne16
I don't think I've manually turned my lights on since 2003.
Old Mar 29, 2006 | 08:09 PM
Michael Tucker's Avatar
Michael Tucker
Never use it!!! if the motors and gears are weak they will gey weaker at 75 or 80 mph when the lights pop up. i started pulling off the road and stopping to turn on my light after i replaced the first motor in 2002.
Old Mar 29, 2006 | 08:47 PM
TripleBlackxThree's Avatar
TripleBlackxThree
St. Jude Donor '07
Originally Posted by MrLeadFoot
1)
4) If it was completely illegal to drive with only fog lights, the car manufacturer would not have made it possible to drive with only fogs.
Sorry, this one made me laugh a little... following this line of reasoning our cars surely wouldn't be capable of 170MPH.
Of course driving lights are best used with headlights. Although the lights on our cars stock are so bad that with good driving lights it's hard to tell if the headlights are even working.
As for driving with just fogs (the stockers) at night in fog... I'd keep it under 20. If the fog is so bad that the glare from properly adjusted low beams is blinding, it's too foggy to drive.
Old Mar 29, 2006 | 09:04 PM
chocoholic's Avatar
chocoholic
1) I guess you've never driven at night in the fog.
2) Dependencies are irrelevant. High beams and low beams BOTH shine higher, thus, BOTH cause undesirable reflection.
3) Duh, fog lamps and driving lamps are different. Fogs are low-powered and meant to reduce reflection off the fog.
And, FWIW, some laws are allowed to be broken. For example, you can break a traffic law when it's safer to NOT adhere to the regulation. For example, while you would normally get a ticket for driving down the shoulder of the freeway, if there was too much water from a heavy downpour in the normal lanes of traffic, you can be excused for driving on the shoulder. Similarly, you can get a ticket for driving 55mph in a 55mph zone if fog is so heavy that that speed is deemed unsafe for the conditions. The same holds true for fog lights. Typically, it is unsafe to run only fog lights at night because other drivers may not be able to see you well, due to fog lights being low-powered. However, if it's safer to run only fog lights, as might be the case in heavy fog, you can be excused.
Driving lights, on the other hand, are designed to assist in normal night driving, and are meant to be used in conjunction with low beams. In most states, it is illegal to drive with only driving lights. They MUST be used together with headlights. But, this is a moot point on this thread, because Vettes don't come with driving lights, and nobody was talking about driving lights.
Apparently.
OK, so you're arguing all points at once now. And, yes, it seems I have driven a lot more in fog than you. But have fun anyway.
Old Mar 29, 2006 | 09:07 PM
MrLeadFoot's Avatar
MrLeadFoot
I think you're taking this out of context. There are DOT (Department of Transportation) regulations that concern vehicle lighting.
Hey don't flame me on this one. Somebody else posted something on this, so I was just correcting the incorrect posting.
No argument here!
And, with the denseness of the fog we sometimes get, you're smarter to go even slower than that, if in fact you even choose to try driving in it! Some people just pull off the road and wait it out.
Uh... I have to disagree with you here. Heavy fog is MUCH easier to drive in with only fogs on, although that's not saying it's a breeze to drive in it with only fogs. But, I've driven in all kinds of fog in different parts of the world, and if you keep your headlights on, I've found you can't see anything in front of you except the fog. However, I've also found that if you run only fogs, you can at least crawl through the fog.
back at ya!
RedWolf's Avatar
RedWolf
St. Jude Donor '08-'09
Don't use it. The garage door opener light comes on which lights up the garage.
Old Mar 29, 2006 | 09:10 PM
Hopalong's Avatar
Hopalong
I don't drive at night...
Besides, when the lights are up, there is so much drag ,that it's not even like driving a Vette.
Old Mar 29, 2006 | 09:12 PM
CorvetteGirl-NM's Avatar
CorvetteGirl-NM
Cool. Good to know. Might just start using the feature and see how I like it. Guess I need to RTM.
Originally Posted by MyVetteDream
Go Lori Go!
I read something about 'twilight sentinal' and 'headlamp delay' in the manual but havn't tried it... might give it a shot. Love the gadgets on my car
Old Mar 29, 2006 | 09:13 PM
MrLeadFoot's Avatar
MrLeadFoot
Of course, I'm arguing all points, cause you were plain wrong. And, how do YOU know you've driven in more fog than me? Who cares anyway?
All I know is I know what works and what doesn't, what is legal, and what is illegal.
I didn't bring all this up... you did. I was just stating what factory options I like to use as a point of reference to the original poster of this thread who asked whether or not I used the Twilight Sentinel option, and if not, why I didn't. Then, YOU came along and flamed me. What'd you expect me to do? Let you tell me I'm wrong, when what you posted was wrong itself?
Why is it that it's ok to flame me, and I don't have the right to substantiate my position? Sheesh...
Now, where is that emoticon with the guy puking when you need it?
Edit: I found it:
OK, now I can say at least I learned something from this thread.
My apologies to Girl-in-a-Box for this thread getting out of hand.
Old Mar 29, 2006 | 09:43 PM
  #33
TripleBlackxThree
St. Jude Donor '07
You missed the wink! Still made me laugh.
No flame for you or anyone else. I strongly agreed with someone.
Uh... I have to disagree with you here. Heavy fog is MUCH easier to drive in with only fogs on, although that's not saying it's a breeze to drive in it with only fogs. But, I've driven in all kinds of fog in different parts of the world, and if you keep your headlights on, you can't drive. But, if you run only fogs, you can at least crawl through it.
Lot's of miles behind me as well and have never had a problem with low beams in fog except when they were aimed to high (or too much beef in the back seat, making the car squat ). I couldn't never see anthing with my fogs at night without the lows on.
All that said, if you can deal with the coastal fog you get there, you are doing something right.
Another good point:
Me too....
Old Mar 29, 2006 | 09:54 PM
  #34
tmcclaff's Avatar
tmcclaff
St. Jude Donor '04 & '05
Originally Posted by RocketDawg
Didn't even know we had headlight delay ... and wondered why not. Guess I need to go fiddle with my DIC ....
Old Mar 29, 2006 | 10:42 PM
  #35
MrLeadFoot's Avatar
MrLeadFoot
I guess I did miss the wink.
Old Mar 29, 2006 | 10:48 PM
  #36
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Originally Posted by WvCorvette
I tell my wife the same thing.....use it or lose it!!!
I tell my husband the samething but it never works
Old Mar 29, 2006 | 11:16 PM
  #37
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I don't use it. I like to think that I'm still smart enough to figure out when I need to turn the headlights on.
To Use it or lose it?
Old Mar 29, 2006 | 11:19 PM
  #38
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Old Mar 29, 2006 | 11:24 PM
  #39
2vettes2go's Avatar
2vettes2go
yeah, i have it on our 03ae. really nice to not have to worry about reaching down and turning hdlites on. very helpful for tunnels and other dark palces. just set it and forget it, like the delay turn-off. sometimes they do come up with usefull stuff. good going gnb..lol
Old Mar 29, 2006 | 11:36 PM
  #40
ConvertedWS9's Avatar
ConvertedWS9
Originally Posted by BAD_TCR
There is a delay, but there's just no way I want those lights worked out anymore than they have to.
You can rebuild them with a brass gear ($30) and have a motor that will probably last longer than you willl even keep your car.
