[Z06] question about CCW wheels
Old Mar 30, 2006 | 04:20 PM
SkyWarp's Avatar
SkyWarp
Default question about CCW wheels
I plan on getting CCW classic's. I want the 18x11.5 on the rear with 18x10 on the front. I will be running 335/30 on the back. How much do the rear stick out from the fender?? pics would be great tks
Rob
Old Mar 30, 2006 | 04:29 PM
CDH76's Avatar
CDH76
I have 305 on right now, they do not stick out at all. Not much help, but just giving you a little idea.
Call John at CCW and ask. I'm sure he knows
Old Mar 30, 2006 | 04:32 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
The "big street" package is what you're describing. they stick out about 1/4" from the body work... it looks mean. However I chose 18x9.5 and 18.11 w/ 275's and 295's to retain my rear brake ducts and have the outer edges perfectly flush with the body.
Old Mar 30, 2006 | 05:12 PM
Miguels's Avatar
Miguels
OEM size rear and tire
http://www.nitekrazze.com/images/Cor...ls-OEMSide.JPG
19x11 64mm offset rears 305/30 tires
http://www.nitekrazze.com/images/Cor...-C6Z06-Top.JPG
http://www.nitekrazze.com/images/Cor...6-BackSide.JPG
Old Mar 31, 2006 | 12:26 AM
striper's Avatar
striper
I have 295's on 11" wheels on my Z06 and the sidewalls do stick out just a hair. I also stayed with the 295's so I wouldn't have to remove the rear ducts. Make sure you tell them you've got a Z06 so they will provide the correct offset. I'm using 265's on 10" wheels in front, sticks out the same as the rears. The 265/295's will keep the exact same diameters as stock.
To question about CCW wheels
