TPM question
Old Mar 31, 2006 | 08:30 AM
SlickVic's Avatar
SlickVic
Default TPM question
I have put some new rims on my car and Im getting a 0 reading from the left rear tire says it flat??? all the others are fine
I had a front one not reading but that seems fine now
these are off a 2004
the tire is not flat
what should I do
should I re learn the sensors?
anyone ever have this issue
thanks guys!!
Vic
Old Mar 31, 2006 | 09:05 AM
DeeGee's Avatar
DeeGee
When I got a flat it read 8psi
From what I've heard it wouldn't read 0 if the sensor battery had failed but not sure on that
I'd start with a relearn
Old Mar 31, 2006 | 09:18 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Did you train the sensors before putting them in the wheels?
Have you driven the car much since?
When I put my wheels and new sensors on, I did train them to the car before the tires went on the wheels. At that time, all 4 were showing 0psi on the DIC (and of course, the barrage of flat tire warnings).
When they got mounted on the car, it took quite a bit of driving (10-15 mi) before all 4 were were displaying new, correct readings.
The old 'flat" readings remained during that time, since the DIC will display the last reading until a new update is received from the sensor. The sensors don't transmit often when the car is parked (to preserve battery life), so go drive it for a while if you haven't done so.
To TPM question
