Nitrogen for tires
Old Apr 1, 2006 | 01:28 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
Default Nitrogen for tires
Has anyone ever used nitrogen in their tires? If so, did you like it? Where did you get it?
jeff
Old Apr 1, 2006 | 01:31 PM
JTS97Z28's Avatar
JTS97Z28
You wont notice any difference. Its a technology that began from Aviation because I believe it wont effect the pressure at different temperatures and wont condensate. Someone please correct if I am wrong. In a passenger vehicle wont make any difference.
Hope this helps.
JT
Old Apr 1, 2006 | 01:39 PM
bill bradford's Avatar
bill bradford
Nitrogen is a drying agent. The tires will not expand or contract in different temperatures. The rubber will not deteriorate. It is better than air. I would use it for racing only, not a big difference in a daily ride. You can get nitrogen at any gas dealer. Yes it is safe, but if released it does take oxygen, so if you get dizzy just walk away and get some air.
Old Apr 1, 2006 | 02:29 PM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
They say that since theres no moisture in it tires will last longer, However look at an old set of tires they will rot from the outside in not from the inside out. Airplanes use nitrogen in there tires to keep from getting ice in them at altitude, most cars dont have that problem.
Old Apr 1, 2006 | 03:04 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Ah, nitrogen makes up 78% of the air you already breath and it is in your tires
Old Apr 1, 2006 | 03:11 PM
63C2splitter's Avatar
63C2splitter
CF Senile Member
St. Jude Donor '08
Compressed air is about 70% nitrogen.
The big benefit to nitrogen (as it pertains to Aircraft), is that the molecules are larger than oxygen, and therefore have a slower rate of leaking should the tire have a small penetration. All tires leak air through the rubber (especially at the high psi of a large aircraft ~250psi). Though it is not an FAA requirement to use nitrogen, most large aircraft manufacturers call for it's use. Tire deterioration is not a consideration, as most AC tires have a very short service life.
The small amount of moisture that is present in compressed air can change the pressure slightly (1 to 2 psi) in a racing tire as heat increases. Probably would never see this in a non-racing application.
I don't see any benefit to inflating your tires with nitrogen.
I am sure there are other considerations than the ones that I have mentioned. Interested in hearing from others. (I have worked for Boeing for many years (Military Aircraft), and have always seen them use nitrogen in the aircraft tires).
Dave
Old Apr 1, 2006 | 03:32 PM
bigcypress's Avatar
bigcypress
we run approximately 78% nitrogen and 21% oxygen and it works great .
Old Apr 1, 2006 | 04:12 PM
csmith46's Avatar
csmith46
it works for me. i usually had to refill my tires every 2-3 weeks to keep pressure up to par. after the nitrogen fill up i didn't have to add for almost 8 weeks. only lost 2 pounds in 2 months instead of 2 pounds in 2 weeks. there are lots of theories as to whether or not it's worth it but doing it answers your questions. as to deterioration I agree tire won't live long enough anyway to notice that difference. good luck
Old Apr 1, 2006 | 07:23 PM
JeffC5's Avatar
JeffC5
Thanks for all the replies. I thought if you put nitrogen in your tires, the pressure would stay the same during cold and warm weather. I also thought it wouldn't leak out, so you'd never have to add anymore. But, after reading your responses, I'll just stick to plain ole free air. Plus, I called around and no one here has nitrogen for tires.lol
jeff
Old Apr 2, 2006 | 12:48 AM
rac03's Avatar
rac03
I just got tires at a new Costco and they use nitrogen.
Old Apr 2, 2006 | 12:51 AM
dndrsn's Avatar
dndrsn
I put nitrous oxide in mine, it makes em happy.
Old Apr 2, 2006 | 12:52 AM
F.J.B.'s Avatar
F.J.B.
From: Vette Doctors Performance RX450 - 466RWHP !!!
I prefer using Stock Air. Nothing but Stock Air!
Old Apr 2, 2006 | 01:27 AM
Wisdom's Avatar
Wisdom
I agree, I use stock air too! But I've found that compressing it a little over twice ambient air pressure seems to give me the best performance and gas mileage. And by compressing the stock air, I get more than twice the amount of nitrogen (for free) than I would get at ambient pressure - and it doesn't change the O2/N2 ratio either!
- Wisdom
Old Apr 2, 2006 | 03:32 AM
David426's Avatar
David426
I use helium in mine. It makes the car much lighter
Old Apr 2, 2006 | 04:14 AM
RebelVette's Avatar
RebelVette
I'd say this Forum is about 78% smart@$$ and 21% know-it-all.... and I love it!
Old Apr 2, 2006 | 04:18 AM
2MuchRiceMakesMeSick's Avatar
I got some land I want to sell some of you....
Old Apr 2, 2006 | 04:28 AM
LS9's Avatar
LS9
Nitrogen is a drying agent. .
uh, no
it just has less moisure
it will not actively do anything
To Nitrogen for tires
Old Apr 2, 2006 | 04:29 AM
LS9's Avatar
LS9
you missed Mythbusters helium and the football episode
Old Apr 2, 2006 | 04:33 AM
pewter99's Avatar
pewter99
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I had it put in my 335's when they were mounted but thats what the guy who installed them does as part of his service...I will say they hold pressure better as someone else mentioned above...
www.pitcrewtire.com
Old Apr 2, 2006 | 08:13 AM
DeeGee's Avatar
DeeGee
Me too but I still see about 3psi rise as the tires warm up.
To me there's no apparent improvement and its a transparent gain (forgive the pun)
