door speaker rattle
Old Apr 1, 2006 | 03:39 PM
Mike Mercury's Avatar
Mike Mercury
Default door speaker rattle
since I had the C5 in my shop for the HUD install, I also decided to tackle the door speaker rattle problem.
Using info gained from CF, I learned the BOSE emblem was the main culprit.
seems the most common question is how does the grille come off?
here is a pic from the underside of the door panel:
with my gray interior, you can see tabs from the gray colored speaker grille poking through the door panel and folded over. What this means it that there is no way to remove the speaker grille without removing the entire door panel first; which has been reported here many times.
here is a pic of a removed door handle bezel - and the 5 tabs that are so difficult to see when removing it:
the Bose emblem that is prone to rattle has two prongs protruding from the back. These are pushed through the front of the grille and folded over from the back - similar to bending over protruding nails in wood. Here is a picture of the emblem removed:
these prongs won't tolerate much flexing... or they will break off, so try not to move them any more then needed. There already was a felt piece attached to the back of my Bose emblem, but it wasn't enough to avoid rattling, so I added some silicon rubber to the back and reinstalled.
here is a pic from the back side of the installed emblem, with the prongs folded over:
Also, the black plastic spider-webbed protector(whick lays directly up against the black grille cloth and metal grille) was also a source of rattle. If I tapped on the outside of the grille - at the center - the grille would flex just enough to slap up against the plastic. So I placed a small piece of foam (actually Frost King - minus the foil backing) inbetween there. You can see it in this pic - directly in the center:
Rattles are gone !
Old Apr 1, 2006 | 03:44 PM
sebringsilver97coupe's Avatar
cool. thanks for the pics too.
Old Apr 1, 2006 | 04:32 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Great write-up on the Bose emblem rattle fix. Nice job.
Paul
Old Apr 1, 2006 | 06:43 PM
jers98vet's Avatar
jers98vet
Tim, is it possible to remove the Bose emblem all together??? Or will leave holes exposed in the grille??
Old Apr 1, 2006 | 07:21 PM
Mike Mercury
yes, you can leave it off... it's strictly cosmetic. There is an indentation in the metal grille for the Bose symbol though.
Old Apr 1, 2006 | 07:28 PM
jers98vet's Avatar
jers98vet
Thanks for the great writeup. I'm about to do a complete stereo overhaul. I'm going to follow your frost king install and now I'll be able to fix the Bose emblems as well.
Jer...
To door speaker rattle
