OMG it worked! I LOVE YOU!...if you were here i would make out with you.... ok not really but id give you a big hug! well maybe a big handshake.... anyway YOU RULE!
ok ive pryed pulled and sweated my *** off trying to get the retainer clip off.... HELP!
Glad to hear yours come out. When I got my first Z06 and was trying to put in my B&M Ripper, I could not get the demon key out. We tried everything. It was like someone had put loctite on it and then tapped it in with a hammer
Finally ended up just taking a hacksaw the upper part of the shifter. What the heck, I didn't need it anymore
Glad to hear yours came out. When I got my first Z06 and was trying to put in my B&M Ripper, I could not get the demon key out. We tried everything. It was like someone had put loctite on it and then tapped it in with a hammer
Finally ended up just taking a hacksaw to the upper part of the shifter. What the heck, I didn't need it anymore
Nope, I disagree. The vice grips can slip and rip up the key. I've done this several times and the best way is to use a paint opener from Lowes or Home Depot to gently pry up on the side of the demon key. For those of you that cut off the shaft, sure hope you don't get tired of those short throw shifters - I did. The short throw was not worth the extra effort.
Certainly, there are other ways to do this. Unfortunately, at least some, like the prying method, often result in a sheared key that makes things much more difficult. As I mentioned in the procedure, the vise grip may slip, but don't let that discourage you. Adjust the jaw set position and try it again. I've removed quite a few now and haven't met one that would not come out using this method.
I often have to solve similar "puzzles" for a living and I've found that patience is one of your best "tools" when tackling a tough project.
Dave
It is much like the action of an impact-driver. It is not as much the upward force as it is the impact "jolt" that loosens the deamon key.
This method has worked very well for me four times in a row.....I recommend.
I tried all the methods and didnt have a shot. The key top evetually broke from the all prying, so I broke out the drill and went right thru the key itself. I shall not be defeated!!
