Very subtle bling....
Old Apr 3, 2006 | 01:52 PM
Doug 5.7's Avatar
Doug 5.7
Default Very subtle bling....
Don't let anyone kid you; the install is a bite, (assuming you take the time to clean up the CRUD that will be revealed when you take everything apart!) Yuck, these verts can get dirty!! I went the cheap route via Auger and am happy with the results. I'll change out again someday, when I can't stand the seats any longer. I like the subtle approach. (if its too subtle for your screen, these are black with yellow sticking) plus momo, and airbag decals. Enjoy!
Old Apr 3, 2006 | 02:55 PM
dreamscometrue's Avatar
dreamscometrue
very nice....I'm with you on the subtle theme. Mine is red and silver stiching, I still need to get the airbag letters and wheel flags.
Old Apr 3, 2006 | 03:16 PM
BrianWe's Avatar
BrianWe
Looks good, but you may want to take it apart again. I notice that the top right portion of your radio bezel is stickig out. That means you probably didn't get it lined up correctly on the install. There is a very suble tab on the bottom right, which will cause this if is not in just so. Save yourself time by not taking out the center console, just slide it all the way back after you take off the bolts and you'll be able to adjust the radio bezel.
Good luck.
Old Apr 3, 2006 | 05:18 PM
Looking good, Doug. Nothing wrong with some subtle changes.
Old Apr 3, 2006 | 05:22 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Very nice, looks great!
Old Apr 3, 2006 | 06:06 PM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
every time i see this mod i want to pull the trigger more and more
Old Apr 3, 2006 | 06:47 PM
b98's Avatar
b98
Old Apr 3, 2006 | 06:50 PM
Dark-Knight's Avatar
Dark-Knight
Looking good!
Old Apr 3, 2006 | 08:39 PM
Doug 5.7's Avatar
Doug 5.7
Thanks all. Brian, good catch. I'll take a look, and try again, but I fear it may just be the gap the General ordered...... Hopefully not, and I'll be able to move it. Thanks again!
Old Apr 3, 2006 | 09:22 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
Old Apr 3, 2006 | 10:42 PM
pjm710's Avatar
pjm710
ill add that one to the list
Old Apr 3, 2006 | 11:02 PM
Dr. Dan's Avatar
Dr. Dan
That's how it all starts.
Old Apr 4, 2006 | 12:55 AM
BrianWe's Avatar
BrianWe
Play with it a bit. The General didn't order the gap. I made the same mistake once when I took apart my dash. I didn't notice it until I sat in the passenger seat. I opened it up again and was able to fix it.
-Brian
Old Apr 4, 2006 | 01:19 AM
eitspc5's Avatar
eitspc5
-Brian
Sweet!
Looks familiar, mine are from redlinegoods however. I also prefer the subtle accent! Next are the seats!!
By the way, mine has a gap there as well...fit and finish are not the greatest...
Old Apr 4, 2006 | 02:18 AM
edensknight's Avatar
edensknight
Looks awesome!
To Very subtle bling....
