best intake system for c5
Old Apr 5, 2006 | 10:47 PM
mk8k8's Avatar
mk8k8
Default best intake system for c5
hi, guys just recently got a c5 and was wondering what intake system is the best and has teh best results. vararam or K&N
Old Apr 5, 2006 | 11:22 PM
idontknow's Avatar
idontknow
vararam by far but the quality of the product is crappy. but you cannot deny the numbers from it
Old Apr 5, 2006 | 11:48 PM
Phoenix FRC's Avatar
Phoenix FRC
For about the last month I was trying to decide too.
I finally bought the Vararam because it's source is outside air not pressure from under the car.
With the other systems it takes about 1/2 mile to get the hot air out from under the car and the vararam just keeps pulling air from outside the car.
The Vararam should give you the best results at the track for this reason.
If you don't go to the track then save a buck but you wanted to know what ws best.
The Vararam is spendy too but I still bought it.
I like the flow tube on the K&N but not enough to make another choice.
Old Apr 6, 2006 | 12:11 AM
Cruisin''s Avatar
Cruisin'
I have also heard some good thinks about the Callaway Honker. I'm looking at that right now. Pricey though ...
Dave68's Avatar
Dave68
If you live in California, think twice about the Vararam, as it can be a royal pain to install/uninstall/reinstall for smog tests. If you live in a state that doesn't have visual inspections, then take a look at the following (grouped by cold air and non-cold air, but in no particular order) and my comments, if any:
Vararam: Brings cold air in through the fog light panel area to a panel-type filter. Owners have had good luck with system on the dragstrip, but plan on spending hours to install and a bit more to get everything lined up well. Downside: Eliminates engine bay-cooling air that would've come in from the fog light panels (Z06 or coupe/vert with opened-up panels), so the engine bay may end up being toastier, especially if you add headers later. $350-$400
Vortech Rammer: Brings cold air up from in front of the radiator and into an enclosed box. Its filter is quite a bit smaller than the Halltech Warhead or Blackwing unit. $250
Callaway Honker intake system: This one relocates the MAF so that it is just in front of the throttlebody. It directs cold air from underneath and costs about $500. I believe this unit is 50 states legal (smogwise). Excellent design.
K&N FIPK: This is more of a semi-cold air system, as the cold air intake opening is more of a slit. Its filter endcaps are carbon fiber. However, it is configured similarly to the Halltech Stinger-R and is 50-states legal. $350
Warm air systems: (Easy installation)
Halltech Stinger-R: Not only contains the massive Warhead filter, but also includes a larger-than-stock airbridge and smooth throttlebody coupler. For $239.00 or less, this system represents one of the best bangs for the buck. Fortunately, for about $40, you can add cold air induction. See my procedure at http://www.conceptualpolymer.com/corvette_c5_corner.htm
Halltech Stinger SSM – 2001-2004 C5 only (new!): This intake system features an even larger filter than that of the Stinger-R, TRAP, and Blackwing. $400
Blackwing: Includes just a large filter, but an excellent one at that. Its cost is close to that of the Stinger.
Volant Twin Cone: This system gives you more open filter surface area than any stock box does and is well suited to an engine bay that gets cold air in from the fog light panels, as the filters are more or less in the air flow path. $265
2002+ Z06 airbox cover: A larger opening allows more air to be drawn in through the filter. Expect up to a 5 RWHP gain from this simple swap. $50
Zip-tie: An easy and inexpensive mod (eliminates the OEM box’s upper lid), but its sealing ability is questionable at best.
How good are they? My experience has shown that most will bump up RWHP by at least 10. The advantage of having cold air is that power will not be "dialed down" under normally hot underhood (and intake air) conditions. You could easily lose 10 HP with a warm air system after engine bay temps rise during slow-moving conditions. Cold air prevents this from happening.
Old Apr 6, 2006 | 06:56 AM
Dark-Knight's Avatar
Dark-Knight
LPE has got a new airbox/mass-air combo that is supposed to have some fab numbers, like 20 rwhp and 10 rwt over stock. You might want to check it out. I got the parts on order and if they arrive may do the install by the end of the week. If they don't get here soon it may be June before I can get to it with my travel schedule.
Old Apr 6, 2006 | 07:02 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
If money were no object, that is the way I would go. Probably out-performs the vararam. (Just said that for fun)
Old Apr 6, 2006 | 07:06 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Great post.
Old Apr 6, 2006 | 09:13 AM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
You might also try a search over in the C5 Tech section. I know there were recently a few (long) threads on this very subject. Probably more info that you might want...
Old Apr 6, 2006 | 09:24 AM
Jims99frc's Avatar
Jims99frc
Phoenix FRC , that is a nice car you have there .
I have the Vortex Rammer , works well for me .
Old Apr 6, 2006 | 10:11 AM
threewinmag's Avatar
threewinmag
21st Century advocates the Hurricane. It replaces the radiator shroud and still brings in outside air. No problems with hydrolock, either.
Old Apr 6, 2006 | 10:20 AM
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
CI 4-6-8 & 10 Veteran
St. Jude Contributor
I'm about to put one up for sale in C5 parts. -Including a cut and riveted shroud - I love the thing but with my living in a place at elevation 8 feet, there is standing water on the streets very often and I am too nervous to drive a car with a bottom-breather intake anymore.
Mk8k8,
If you are looking at one of the intakes that cuts the shroud (or a vera-ram) be sure you can live with the extra risk of water-ingestion.
Old Apr 6, 2006 | 10:24 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i've got a honker on the way. you can find them for $50 cheaper than anywhere else I've seen on ebay.
Old Apr 6, 2006 | 10:25 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Very happy with my Hurricane intake!
Old Apr 6, 2006 | 10:29 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Wow - Great writeup. Thanks
Old Apr 6, 2006 | 10:47 AM
Milkman2's Avatar
Milkman2
St. Jude Donor '06-'07
Can't wait until this weekend to do the Cold Air Mod for my Stinger with Dave68 at my side!!!: See you Saturday Dave. thumbs:
Old Apr 6, 2006 | 10:57 AM
RWVH's Avatar
RWVH
Honker all the way . Quality is outstanding, numbers are great. Corvettes of Houston had them on sale, 100.00 off with free shipping and they are supporting vendor. Give them a call, they will work with you.
To best intake system for c5
Old Apr 6, 2006 | 11:34 AM
ORANGEBROTHERS's Avatar
ORANGEBROTHERS
Love my Volant, car pulls much harder now...
Old Apr 6, 2006 | 11:41 AM
tjcleary's Avatar
tjcleary
+1 for vararam
Old Apr 6, 2006 | 01:02 PM
sgtzim's Avatar
sgtzim
St. Jude Donor '11
Wouldn't this procedure work with the K&N as well?
