Oil and Filter?
Old Apr 6, 2006 | 07:33 PM
Jim2003's Avatar
Jim2003
Originally Posted by JDs00PewterCoupe
I use Mobil 1 Fully Synthetic 5W30 oil and an AC Delco PF-46 filter.
As per the manufactors recommendations
Old Apr 6, 2006 | 07:47 PM
binkysgarage's Avatar
binkysgarage
Mobil 1 with K&N gold series filter. I have run Wix filters before, but hard to find, I would run Amsoil but can't get a good deal on it.
Old Apr 6, 2006 | 07:52 PM
jrose7004's Avatar
jrose7004
I use Mobil 1 and the K&N filter.
Old Apr 6, 2006 | 08:07 PM
TEXHAWK0's Avatar
TEXHAWK0
Use Wal-mart TECH 1, Fully Synthetic oil and FRAM filter. Make sure it says "fully synthetic". Don't get the cheap stuff for the Corvette.
Wal-mart brand meets GM 4718M and a few more specs. that even Mobil 1 cannot meet.
(Just wanted to see if anyone was really reading these!)
Old Apr 6, 2006 | 09:43 PM
NEVERL8C5's Avatar
NEVERL8C5
Bought my 99 used from Douglas Jeep Polaris in Venice Fl. They put in the cheap stuff and a white label filter when they serviced the car prior to delivery. 32 days after purchase I was looking at a $10k dealer installed engine. Nuff said.
Old Apr 7, 2006 | 03:59 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Originally Posted by binkysgarage
... but hard to find, I would run Amsoil but can't get a good deal on it.
Dropped you a PM.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Apr 7, 2006 | 08:58 PM
Allen N. Schmidt's Avatar
Allen N. Schmidt
Default Filter
K & N. The one inch nut at the bottom is the greatest invention known to man on a filter. Saw an add in Motor trend for a outfit in San Diego for $8.99. Good deal
Old Apr 7, 2006 | 10:44 PM
chocoholic's Avatar
chocoholic
Read your owner's manual and actually read your oil filler cap. When you do that, you'll find that there is NOT a particular brand of oil that is recommended.
What is recommended is an oil that meets GM4718M and that's it. Beyond that, you're either into oil analysis, voodoo or sheep following. I've even seen it said on BoilIsTheOilGuy, that some of the SuperTech (Walmart as mentioned by texhawk) oils are suspected of being made either by Exxon-Mobil or Warren.
Old Apr 7, 2006 | 11:15 PM
C5LawnGnom's Avatar
C5LawnGnom
Welcome to the forums, My name is Ian and im 14 years old, youngest one here. K&N Filter Mobil 1
Old Apr 7, 2006 | 11:36 PM
rgtkst's Avatar
rgtkst
Originally Posted by PashaCorvette
Just changed mine yesterday Mobil 1 5w-30 (6.5 quarts),and filter again Mobil 1. it`s little pricey but I guess worth it.
and it says it on your oil filler cap too. 6.5 qrts on my 2000.
7 seems to make it too full and there is a service bullitin out that says over the full line will cause the counter wieghts on the crank to churn up the oil. and in turn your lifters will cause noise because they have foamed oil in them. the air bubbles cause them to not pump up enough and cause clatter. i thaught my car was pinging and the tech showed me the problem and no more ping noise.
Old Apr 7, 2006 | 11:40 PM
zbest4me's Avatar
zbest4me
Welcome to the forum.
just make sure you do a proper change on it. If you don't drain all the oil out, you will be adding WAY to much.
Old Apr 8, 2006 | 12:09 AM
Oldvetter's Avatar
Oldvetter
Raising the rear when draining oil only drains 4 more ounces.
Old Apr 8, 2006 | 12:22 PM
  #33
rgtkst's Avatar
rgtkst
my cap reads as follows,
"ENGINE OIL"
"sae"
"5w-30"
"Mobile 1"
"factory fill"
"NOTICE"
"see owners manual"
"special engine oil required"
seems kinda like a recomendation to me!
i guess they could just be trying to tell you the factory uses it
i am sure that the amsoil or others that meet the minimum requirements are just fine. some may exceed the factory fill. but what really IS
the GM4718m???
Old Apr 8, 2006 | 12:41 PM
  #34
filmelf's Avatar
filmelf
St. Jude Donor '06-'08
Mobile 1 5-30 and K & N filter for me
Old Apr 8, 2006 | 03:45 PM
  #35
Laguna Blu's Avatar
Laguna Blu
Anybody use the Mobil-1 0W-30? I would imagine that it protects the same way as a 5W-30 or 10W-30 would when up to temps and has the advantage of flowing better than the others when cold.
Old Apr 8, 2006 | 08:23 PM
  #36
Patman's Avatar
Patman
I have the oil analysis results which prove that the German made Castrol Syntec 0w30 is a considerably better choice than Mobil 1 5w30.
I've never seen oil analysis results with Mobil 1 5w30 in an LS1 that even come close to the results I've been consistently getting with GC 0w30.
Mobil 1's advertising is very good, it makes people think it's the best oil but it's really just an ok oil. There are a lot of better synthetic oils out there than Mobil 1 (such as Amsoil or Redline)
Spend some time on www.bobistheoilguy.com (specifically the used oil analysis section of the message board) and you'll believe me.
Old Apr 8, 2006 | 09:06 PM
  #37
Laguna Blu's Avatar
Laguna Blu
I guess alot has to do with availability at the local parts store. Also how can one differentialte between German Castrol & American Castrol?
To Oil and Filter?
Old Apr 8, 2006 | 09:19 PM
  #38
Cruisin''s Avatar
Cruisin'
First off ... Congrats and Welcome! A new millennium car. Very Cool. Enjoy it, I know you will.
Second, take your owners manual and leave it in the bathroom. It makes great "crapper" fodder. Read it and it will give a l lot relevant information. It's bit on the dry side, but if read a little at time, it's worth it.
Old Apr 8, 2006 | 10:07 PM
  #39
TEXHAWK0's Avatar
TEXHAWK0
the GM4718m???
The main requirement of the GM 4718M spec. for the Corvette is better performance in high temperature/high shear environments, and lower oxidation rate, also a necessity in an engine generating high oil temperatures. These differences mandate synthetic oil because petroleum-based oils cannot meet the higher requirements. Better high temperature/high shear numbers and lower oxidation rates are characteristic of all quality synthetic oils. Practically all the name brand synthetic oils like to mention they meet the Corvette spec. even if it does not appear on the label. In fact, even the new Mobil 1 bottles do not specifically mention the GM 4718M spec.
Don't worry so much about the 4718M spec and just look for a major brand of synthetic oil meeting API SL/SM or ILSAC GF-3 or 4, like Amsoil, Red Line, Mobil 1, Castrol Syntec, Quaker State Full Synthetic, or Havoline Synthetic to name a few.
(Just kidding about the Walmart synthetic in earlier post)
Old Apr 8, 2006 | 10:32 PM
  #40
av8or's Avatar
av8or
Checked out bobistheoilguy.com site......right at the top is an ad for Castrol. hmmmmmm. Lots of objectivity there.
I follow Click & Clack the Tappet Brother's advice: Buy any oil that meets the requirements and change it per the owner's manual.
Mobil 1.
