Windshield Glare/Reflections
Old Apr 6, 2006 | 10:30 AM
rwsr50's Avatar
rwsr50
Default Windshield Glare/Reflections
Anybody else think they get an awful lot of glare and reflections off the dash on their C5? Mine is really annoying. I've cleaned the windshield, inside and out, and the dash, more than on any car I've ever owned, but this is annoying and distracting.
I'm thinking it's because of the steep angle of the windshield, and the fairly long depth of the top side of the dash.
Old Apr 6, 2006 | 10:39 AM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
But, it's a minor issue. I've driven cars with worse windshield glare and a lot less appeal than my 'vette.
Old Apr 6, 2006 | 10:41 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
You're right it can be a pia, but not too bad. I agree with you concerning the configuration of the windshield. Not much to do but grin and bear it.
Old Apr 6, 2006 | 10:42 AM
DeeGee's Avatar
DeeGee
Quite a bit
I was making the mistake of using gloss dash cleaner which made it much worse. there are some products that dry to a dull finish that may help.
Old Apr 6, 2006 | 10:45 AM
DjCritterus
St. Jude Donor '09
Originally Posted by DeeGee
Quite a bit
Don't use anything silicone based. But then again, water based stuff like Armoral will fade and leave a film if you don't keep up with it.
Old Apr 6, 2006 | 10:46 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
buy a pair of polorized sunglasses with anti glare coating on them and you wont see it....
Old Apr 6, 2006 | 10:56 AM
KMeloney's Avatar
KMeloney
Very, very true.
And stop cleaning your dash! Just wipe it with a damp cloth to get the dust off. The shinier it is, the more it's going to reflect. Keep it dark and dull.
-Kirk
Old Apr 6, 2006 | 10:58 AM
OrangeVegaGT's Avatar
OrangeVegaGT
St. Jude Donor '06-'07
More of a problem with a CE or AE as the shale color magnifies the problem. Downside is the HUD is dimmed quite a bit, but still readable.
Old Apr 6, 2006 | 11:06 AM
rwsr50's Avatar
rwsr50
Originally Posted by KMeloney
Very, very true.
-Kirk
That's all I am using, a damp cloth. My dash is black.
On a side note, I saw somebody above mentioned Armorall. DO NOT use that on your interior! I used it on a dash on another car I had and the vinyl came loose from the substrate all around the edges. When I asked about it at the dealer, the first thing they asked was if I was using Armorall. They said that can cause it.
Old Apr 6, 2006 | 11:09 AM
rwsr50's Avatar
rwsr50
I was afraid all the good looking women won't be able to see me due to the glare. Now you want me to wear dark glasses yet. They'll never recognize me!
Old Apr 6, 2006 | 11:32 AM
epicshooter's Avatar
epicshooter
Right- this helps a lot but reduces the visability of the HUD....
Old Apr 6, 2006 | 12:51 PM
DjCritterus
St. Jude Donor '09
Armoral is a water based product. It tends to leave a film... then dry rotting, cracking, headaches, etc... if you don't keep on top of it. I avoid that product at all times.
Old Apr 6, 2006 | 06:03 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I'll be the devil's advocate here. I've used Armoral for over 30 years and have never had any problems at all. Other's have said that the dashes will crack and such with Armoral. I disagree. Most say have you used Armoral because for years there wasn't anything else on the market that did what Armoral does. So they could sound as though they knew what they were talking about and sell you something else. I have had motorcycle seats for 20 years and they have had nothing but Armoral and they are in excellent shape. There is my .02 When I use it on my dash I use a micro fiber towel to clean it off and that gets ride of the shinny surface and it looks great.
Old Apr 6, 2006 | 06:32 PM
DjCritterus
St. Jude Donor '09
Armol is good if you stay on top of it. For us lazier types that don't get a chance to take care of our equipment but every so often, it's not a good product.
to each his own.
Old Apr 6, 2006 | 06:41 PM
sage666's Avatar
sage666
I have to agree as I've been using Armoral since it first hit the shelves way back when. The only problem area was when installing wood dash kits, the Armoral had to be THOROUGHLY cleaned off or the adhesive would not always hold.
Old Apr 6, 2006 | 08:27 PM
Freestyler's Avatar
Freestyler
get a black matt for the dash or black cutting of felt
a bit grandfather-ish , but ...there ya go
Old Apr 6, 2006 | 10:49 PM
Last C5's Avatar
Last C5
A dash mat completely cures the problem.
To Windshield Glare/Reflections
Old Apr 7, 2006 | 02:30 AM
striper's Avatar
striper
Get polarized sunglasses. They are not as dark as other types of glasses but the glare will totally disappear when you wear them. That's what I do to alleviate the glare problem.
Old Apr 7, 2006 | 06:57 AM
[QUOTE=KMeloneyAnd stop cleaning your dash! Just wipe it with a damp cloth to get the dust off. The shinier it is, the more it's going to reflect. Keep it dark and dull.[/QUOTE]
That's all I have ever used on mine and the glare seems to be pretty much of a non-issue.
Old Apr 10, 2006 | 12:41 PM
richiep's Avatar
richiep
Default Windshield Galre Solution
Try a dash mat; they eliminate the glare. They don't look great, but you can put it on for your drive and take it off if you want to show the car. Most of the ones I've seen (at least for the C3 and C4) use velcro to keep them in place.
