Halltech Stinger-R installation thought
I Just couldn’t make the larger airbridge fit. No matter what I did, repositioning in every conceivable way, even removing the hood liner for more clearance. I just couldn’t get the hood closed properly without the air bridge making the hood bulge. I ended up using the stock airbridge with the stinger filter. I also did the cool air mod that grabs outside cool air. My car is lowered, so I was just thinking if that might have had something to do with it. Maybe my thinking is flawed, but could lowering bring the car closer to the engine, thus the problem? There must be guys that have lowered cars and the same intake, but as I said before, no comments about clearance problems. Does anyone think this is a possible explanation?
It could be that your particular Halltech airbridge is out-of-spec. and that this is probably a rarity, given the absence of complaints.
Another possible reason is that one or more components of a number of assemblies in the engine bay are on the high side of their dimensional tolerance. It's not enough to cause any issues with stock components, but a larger airbridge could very well cause a fit problem. I once worked for a company that employed a guy who measures a part, designed a mating hole to a standard drill/reamer size, and left it at that. If he had checked the part tolerance, he would have found that the part he measured was on the low side. Once a part with an O.D. on the high side was issued to an assembler, that person found that it just would not fit into the hole.
It could be that Jim Hall measured aC5's hood clearance and designed the airbridge based upon those measurements. You C5 comes along with the stackup on the high side and viola - an interference fit!
I think Dave is in the ballpark... just like all LS1 motors are not created equal from the factory..some have a bit more HP and a bit less..same thing with the body/hood of the car.... and same thing with the stinger intake itself..it's possible there is a slight variance in the tolerance or something.
Relax and enjoy that incredible C5!
Jim Hall
jim@corvettec5.com
Anyway, I already had a depression in the hood liner from the stock airbridge, thus my thinking a bigger one wouldn’t fit. So it must be an issue of the “one time occurance” on the car. My car must have an irregularity in the radiator shroud or someplace else making the airbridge taller than most other Vetts.
I really like 02gt350s coment, because that means I’m better off with the stock one.
“it actually seemed like there was MORE power with the smaller stock bridge, which I attribute to the velocity factor, like when the air comes in through the Warhead, then is compressed into the smaller stock bridge.”
And Dave, how did you know my car is incriible?
I went back to the stock airbridge as well, the stinger airbridge collapsed when I tightened it and I had an air leak that took me a week to track down...
