jacking precautions?
Old Apr 8, 2006 | 10:00 AM
Billy52's Avatar
Billy52
Default jacking precautions?
Is there any prohibition against opening the car door while car is on jack stands or otherwise off the ground? A mechanic friend told me you should not open the door under those conditions as the car will "flex" & could damage something.
Anything in the tech manual regarding this?
Old Apr 8, 2006 | 10:04 AM
DeeGee's Avatar
DeeGee
From everything said on the Forum here, that's an old wives tale. Apparently the older Vettes were affected but the C5 is rigid.
All I can say is I've opened my doors many times when its been in the air - gently
Old Apr 8, 2006 | 10:05 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
My understanding from other posts is the whole "flexing" issue is a myth. I would be more concerned just about the general safety of opening the car door while the car is up in the air.
Old Apr 8, 2006 | 10:06 AM
rws.1's Avatar
rws.1
A myth.... from the old days of C3's
Not an issue with your C5
Old Apr 8, 2006 | 10:47 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
It's total that is just a carry over from the old days. The C5 frame is about as rigid as it gets. You can have the roof off, open and close the doors or the hood and hatch till your hears content. Won't make a difference.
Paul
Old Apr 8, 2006 | 10:57 AM
C5naples's Avatar
C5naples
Paul
Old Apr 8, 2006 | 10:23 PM
MrLeadFoot's Avatar
MrLeadFoot
To check to see if I had an internal seal leak in my steering rack, I jacked the front of the car, placed it on jack stands, opened the driver's door, got in, turned the engine on, and turned the wheels side to side. In all this, there was no problem. It was scary, nevertheless, because if I had put it on gear by mistake...
Old Apr 8, 2006 | 10:31 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
C5's and C6's do not flex. These cars are as solid as you can get.
You can open your doors, hood and hatch or trunk with no problem at all.
Old Apr 9, 2006 | 12:34 AM
01QuickSilver's Avatar
01QuickSilver
No problem flexwise - Just be sure you don't fall out !!!
To jacking precautions?
