Front directionals?
Old Apr 10, 2006 | 10:51 PM
Groucho's Avatar
Groucho
Default Front directionals?
I seem to have seen a post or 2 on this..did a search but did not find it...Any advice on getting to them to change a bulb?
I can't see a way to them other than the wheel well?
Thanks!
Old Apr 10, 2006 | 11:53 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Thanks!
Hi Groucho -
There is an access panel on each side, remove the small (8mm I think) bolts that hold the panel on. The bolts go straight up, you either have to get the car in the air somehow or lay on your back -
Once the panel is removed, you can reach up in the cavity to twist the bulb out.
best regards -
mqqn
Old Apr 10, 2006 | 11:56 PM
Groucho's Avatar
Groucho
Default Thx...
To Front directionals?
