Help.....I dropped a socket in the engine compartment
Hi All,
It's been a while but I have a slight problem and wonder if it's a cause for concern. While replacing the battery, my @##^&*% socket fell off the wrench and fell underneath the hole that's already underneath the plastic bottom for the battery. No hope on reaching it as I can't see it, so a magnetic socket wouldn't help. I don't feel like taking that whole section apart, because my expertise is limited to the basics-lol
I'm not sure if there is another hole down at the bottom where it will just fall out if I take it for a spin. I havn't driven it yet, since I've just taken it out of Winter storage, and the darn battery tender didn't keep the battery charged, hence my replacment.
Is anyone familiar with this section of the engine? Will it fall out? Is there a danger of it harming something internally, etc.
*Jack up front of car or right front
*Turn your wheels all the way left, or remove RF wheel
*You'll see the access panel for the car's computer right there
*Remove it and you should be able to get where you need to go.
I did the same thing a few weeks ago. Just remove the access panel as stated above. I still haven't done it, but I doubt anything will be hurt from the socket being in there.
Actually in the owners manual is specifically says
Originally Posted by Corvette Owner's Manual
Any sockets dropped by moron owners into the battery area should be removed instantly. We know your excessive gold chains and chest hair make working on the car harder hard, but still, you must remove the socket instantly or the vehicle will explode
sorry to laugh, but usually we end up with extra bolts and screws when we work on our cars , that musta been really frustrating - I woulda started yelling at my fiance if she was around and blame it on her distracting me or something
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
OMG!!!! You dropped a tool into the BLACKHOLE??
The last person that reported that problem reached down there with a magnetic extending wand and his arm disappeared!
You've heard of the Bermuda Triangle, right? Well, this is the Corvette Triangle.......
Tools have a way of mysteriously disappearing into it - never to be heard from again......
Actually - now that I've gotten that out of my system - I really did use one of those magnetic extending wands and I was able to snag it. Here's a pic of what's in that hole......
I've been able to gain access to this area without jacking the car. You end up having to turn your wheels to the left and the right in order to get all the attatching bolts out. I think they are 7mm.
I dropped a socket there while replacing the stock battery with an Optima Red. Even when I convinced myself that it is ok, I lost a few nights sleep over it. I caved in and retrieved the socket with a magnetic wand after I took out the battery and its tie-down/holder.
I feel your pain bro, I dropped a battery terminal nut while changing out my battery but luckily for me it fell onto the plastic splash guard below that area
If you're positive it fell into that hole (and I know exactly what hole you're referring to ), do think you might be able to fish it out using something like this:
It's on sale at Sears BTW , and works quite well; has a built-in flashlight, powerful magnet, and is telescoping.
Or something like this: Flexible pick-up tool (this baby has little claws that you can use to grasp the socket if you can locate it, and the whole thing is flexible).
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Darn, I was just about to go try this and realized my 7mm bolt was with the others - in the black hole.
I've done the same thing with a socket and taking this panel off made access very easy. There is not hole for the socket to fall out, so if you want it, follow the above.
