Help.....I dropped a socket in the engine compartment
Old 04-11-2006, 11:52 PM
charlene
Support Corvetteforum!
charlene's Avatar
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Originally Posted by blacksedan87
OMG!!!! You dropped a tool into the BLACKHOLE??
The last person that reported that problem reached down there with a magnetic extending wand and his arm disappeared!
You've heard of the Bermuda Triangle, right? Well, this is the Corvette Triangle.......
Tools have a way of mysteriously disappearing into it - never to be heard from again......
Actually - now that I've gotten that out of my system - I really did use one of those magnetic extending wands and I was able to snag it. Here's a pic of what's in that hole......
Happy hunting!
Well with that picture you have on the forum i can now see where the bolt i lost went when i put the new chrome cowl on the car.
Old 04-12-2006, 10:30 AM
Mr. Wonderful
Mr. Wonderful's Avatar
Location: Slower than a speeding bullet................ Fort Lauderdale, FL
Well, I followed the directions above to try and retreive my battery terminal hold-down nut. I found I had to remove the wheel for easier access.
I searched inside there, but did not find it.
I'm glad you other guys had more luck
Old 04-12-2006, 10:37 AM
c5BlackBeauty
Corvette C5 Enthusiast
c5BlackBeauty's Avatar
St. Jude Donor '05, '12-'13, '15-'16, '21
Originally Posted by b98
Just add it to your mod. list and forget it.
Best suggestion yet.
Old 04-12-2006, 01:53 PM
toolluster
toolluster's Avatar
Default Worse Problem
A bunch of years ago I was helping a friend install new solid lifters in his '67 427 & we dropped a small bolt into a lifter bore. Luckily, we were able to see it & eventually retrieved it with a magnatized screwdriver.
Old 04-12-2006, 04:17 PM
C5MILLYELL02
C5MILLYELL02's Avatar
Happy hunting!
BlackSedan87 You didn;t have to take your fendor off just to show where it was
Thanks everybody.....you guys are the best!!!!
Old 04-12-2006, 04:31 PM
ZO6vettepilot
ZO6vettepilot's Avatar
Happy hunting!
It's all about packaging..... did I see Houdini in there?
Old 04-12-2006, 04:37 PM
ZO6vettepilot
Happy hunting!
Old 04-12-2006, 04:41 PM
JR-CRUZN-C5
JR-CRUZN-C5's Avatar
C'mon -
Your Vette Guys - Just Pop A "Wheelie" and it will come out the way it went in!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
JR
Old 04-12-2006, 05:06 PM
Hammie
Hammie's Avatar
Don't feel bad. Went to take out my battery today and dropped the first damn socket I tried on the bolt head. Had to jack her up, remove the wheel, and open the panel just to get in there.
However, thank you. If I hadn't seen this thread a couple days ago, I'dve never known how to access that low area.
Old 04-12-2006, 05:09 PM
sailohio
sailohio's Avatar
Hee Hee Hee!! Doesn't everyone do that? I can't work on my car without loosing something by dropping it down there.
Old 04-12-2006, 05:22 PM
VA 98 VETTE
VA 98 VETTE's Avatar
Originally Posted by JDs00PewterCoupe
I've done the same thing with a socket and taking this panel off made access very easy. There is not hole for the socket to fall out, so if you want it, follow the above.
I did the same thing once and the DIC starting throwing a code that said; idiot...idiot...idiot...idiot...idiot... idiot.
Old 04-12-2006, 05:54 PM
blacksedan87
blacksedan87's Avatar
Location: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
There is no extreme that I won't go to demonstrate my point for my CF buddies! Actually - it wasn't my fender - it was a Vette owned by some guy in the parking lot. He came out while I had it off, and asked what the heck I was doing. I told him I was trying to demonstrate a point for my CF buddies, don't worry I'll put it back! Geez, some people are so picky!
Old 04-13-2006, 05:59 AM
  #33
Deputy
Deputy's Avatar
OMG. I thought I was the only one this had happened to! I've droped two sockets into that dang abyss. They have been there for years. I thought I'd never see them again. I can't thank you guys enough for all the info you share.
Quick Reply: Help.....I dropped a socket in the engine compartment
