I have never heard of a wheel getting stuck on the bolts though! I know when I was in college a buddy had this happen on his focus... but the first time I have heard this about a vette.
Hang around...you'll see it posted again, I'm sure!
To those who do not have a clue about a car.... the ebrake has nothing what so ever to do with removing a tire or wheel....
there is plenty of clearance between the studs and the wheel holes...
the only thing holding the wheel are those five lugnuts..... although the back of the wheel can rust itself to the axle hub or rotor hat.... I would remove all of the lug nuts, and then slowly lower the car, as the wheel hits the ground it should break any rust.... the studs should be dead center of the wheel holes. once they hit the ground they will move off center.
the other approach that I have routinely used is to loosen the lug nuts approx 1 turn. the back up the car 3-4 car lengths, slam on the brakes, drive forward 3-4 car lengths slam on the brakes. The torques on the wheel from the abrupt stops causes any rust formed between the back of the wheel and the hub to release and free the stuck wheel.
Sorry "Bob", I don't think it's a good idea to lower the car with no lugs on the wheel, that just does not compute. I'm not a rocket scientist, but I've had to fix alot of HUMMVs, 2 1/2s and LMTVs on the run. 13 1/2 years in the Army has made me very mechanically sound.
In theory, it's not a bad idea, but the wheels are hubcentric.
You know this because as you noted, the lugs aren't supporting the wheels, only retaining them. Lowering the car's weight on the unretained wheels likely won't do a thing, since the wheel's center bore is still over the hub...which is exactly the place it is stuck.
This isn't a problem exclusive to any car make or model.
The stuck condition is caused by mounting aluminum wheels against steel hubs. Dissimilar metals in contact with one another cause rapid corrosion, and yes, often produce this problem.
A very light coat of anti-sieze spread around the center hub (Not the lugs) will prevent this from occuring again.
I've done this a few times too. It does work. One other thing to try, if it's a front wheel that's stuck. Loosen the lugs and turn the steering wheel back and forth a couple of times, with the wheel touching the ground. That will usually pop a stuck wheel.
