Or you could drop $275 on some nifty space material ramps
Seriously though, I got two 2x10x10s.
Cut each into 5', 3' and 2' pieces.
Nailed the shorter pieces on top of the longer ones. You can even angle your cuts, but I didn't take the time to do so.
$19 and 10 minutes later I had ~6" ramps that were enough to either get under the front to change the filter/clean the radiator or get a jack under the front.
Rear has never been an issue as long as I don't lift the front too far to start.
JMHO.
These do work great. I did angle cut mine and its a smooth drive up.
Dimensions as above. I screwed mine together. I actually made 4.
