where is the bov?
The SUNAMI will simulate the “psssst” noise generated from the blow off valve of a turbo-equipped vehicle.
The SUNAMI comes complete with all hardware, which includes a manual push button trigger mechanism as well as a vacuum switch trigger mechanism.
After setting a trigger boost level through an adjustable setscrew on the vacuum pressure switch, every time you reach the set boost, the SUNAMI will simulate the “psssst” noise generated from the blow off valve of a turbo vehicle. The blow off valve sound is heard through two speakers mounted under the hood.
An additional override button also allows you to trigger the SUNAMI anytime.
FEATURES:
Push/Pull On/Off switch
Override push button to trigger SUNAMI anytime
Vacuum pressure switch to trigger SUNAMI at a set boost level
5” x 2 1/5” x 1 ½” ABS plastic brain housing
2 durable 12-volt high output speakers for maximum volume and clarity
EZ six wire installation guide
Made in the USA
They even have a sample sound file on there.
FEATURES:
Made in the USA
Dude, I hope you know some of us are just playin around. We know you really know the truth, so don't get all upset and take us seriously or anything
