Air conditioning not working!?
Old Apr 13, 2006 | 06:18 PM
nikolai's Avatar
nikolai
Default Air conditioning not working!?
Tried to use the A/C for the first time this year since it's been on the road and it is spewing out outside temperature air. What could the cause of the air conditioning failure be?
Thanks,
Nick
Old Apr 13, 2006 | 06:56 PM
Albino's Avatar
Albino
Open the hood and tun on the a/c. listen and watch to see if the compressor kicks on. If the compressor doesn't kick on most likely an electrical issue.
If compressor kicks on but no cold air... you have a leak in the system causing the refrigerant to go bye-bye. Have a tech find the leak before they charge it back up, otherwise you will be in the same boat down the road.
Old Apr 13, 2006 | 08:42 PM
1EvilC5's Avatar
1EvilC5
St. Jude Donor '09
Check to see if the compressor belt is still on. I just had one replaced and it is working like new.
Old Apr 13, 2006 | 08:55 PM
masksqueeze's Avatar
masksqueeze
What if the A/C kicks on and the air is cooler then outside but not as cold as it should be? Low refrigerant?
Old Apr 13, 2006 | 09:04 PM
jrose7004's Avatar
jrose7004
You probably need freon.
Old Apr 14, 2006 | 01:08 AM
SLPRC5's Avatar
SLPRC5
All good points mentioned also if freon is too low compressor will not come on a safety feature to keep from burning up copressor due to lack of compressor oil or freon..my $.02
Old Apr 14, 2006 | 05:30 AM
sebringsilver97coupe's Avatar
its broke.
To Air conditioning not working!?
