[Z06] Cleaning Z06 calipers
Old Apr 14, 2006 | 02:48 PM
ricoZg's Avatar
ricoZg
Default Cleaning Z06 calipers
What can I use on my calipers to safely clean them? There appears to be some black grease or grime that soap and water can't remove.
Mike G.
Old Apr 14, 2006 | 05:21 PM
mike85mph's Avatar
mike85mph
Default Try This
This might do pretty good - it works on engines - get the brakes heated up a little then spray them with Windex. Then let it sit a little and hose it off. If that doesn't work then do the same thing but try Simple Green instead.
Old Apr 14, 2006 | 07:10 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Mike G.
Hi ricoZg -
If you have the stock wheels or painted or coated wheel, you can use Meguires Hot Wheels - it works really well at getting the brake dust off of your wheels and calipers.
However - if you have zinc coated brake rotors, stay away from the stuff - it'll stain them instantly.
I use the spray wash at the pressure washer, and the "pre-soak" seems to work pretty good, followed by the high-pressure spray.
Nothing can beat just taking off the wheels and using a rag and some soapy water (car wash soap) on them occasionally.
best regards -
mqqn
To Cleaning Z06 calipers
