Tiger Shark and PIAA HELP
Old Apr 15, 2006 | 01:38 PM
Manchild's Avatar
Manchild
Default Tiger Shark and PIAA HELP
OK I have a problem, I just had a tiger shark nose painted for my car and am trying to put it all back together. I also have a PIAA fog light kit to install but the lights do not fit in the sotck OEM mounts that are on my car and they dont line-up with the new nose. Can anyone that has done this mod or knows how shoot me some help? thanks
Old Apr 15, 2006 | 02:22 PM
Manchild's Avatar
Manchild
Default C5, tiger shark, PIAA, Corvette
I found pics of the install on the lights but nothing on the front end and PIAAs?
Can I use the stock wiring and just splice in?
Old Apr 15, 2006 | 04:18 PM
y2kcorvettebob's Avatar
y2kcorvettebob
Ya might wanna talk to tuan lee, he is the piaa guru
Old Apr 15, 2006 | 04:32 PM
pastorbrad's Avatar
pastorbrad
St. Jude 15 Year Donor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Hi, Bob...wassup?
Old Apr 15, 2006 | 05:57 PM
JimJL's Avatar
JimJL
the original mount brackets have to be bent to line up with the tiger shark
Old Apr 15, 2006 | 08:07 PM
GB Vette's Avatar
GB Vette
CF Over the Hill Member
Cruise-In IV Veteran
CI-4 Car Show Winner
Cruise-In VI Veteran
CI-6 Car Show Winner
Cruise-In VII Veteran
CI-7 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-08-'09
NCM Ambassador
The TS front end for the driving lights comes with offset brackets needed to mount the lights. The stock bracket is inverted and attached to the TS bracket as pictured.
Old Apr 16, 2006 | 01:11 PM
Manchild's Avatar
Manchild
You guys kick ***!
Any other tips on this tiger shark front end mounting will greatly help me and pics if you have any. BTW who is tuan lee and how do I get in touch with him?
Old Jun 21, 2006 | 02:17 PM
Manchild's Avatar
Manchild
Default Thanks
She is done and looks great
see her at www.cardomain.com/ride/2360511
Old Jun 21, 2006 | 02:36 PM
Pumba's Avatar
Pumba
Eric,
Your car looks great ! ! !
- Were you able to reattach the front brake ducts to the Tiger Shark front end?
- Is the Tiger Shark front end compatible with a VaraRam air intake system?
Old Jun 21, 2006 | 04:24 PM
LV_2_XLR8's Avatar
LV_2_XLR8
Originally Posted by Pumba
Eric,
The Tiger Shark front end comes with its own set of brake ducts. They discharge identically to the originals.
I guess it would be possible to adapt the VaraRam air intake to the Tiger Shark front end, but I doubt there is really any advantage, as the Tiger Shark gives you an open shot to the air cleaner anyway.
Old Jun 21, 2006 | 04:59 PM
Pumba's Avatar
Pumba
Ray,
Thanks for the reply.
The important principle of the VaraRam is that it is sealed against the two grille openings on a C5 and takes only cool air from those two locations through ITS AIR FILTER directly to the throttle body.
I would not want a system that dumps air into the engine compartment. That would only add to the front end lift problem that all C5s have at high speed.
To Tiger Shark and PIAA HELP
