Strange - Car will not start
Old Apr 15, 2006 | 02:26 PM
Yoggi's Avatar
Yoggi
Default Strange - Car will not start
Poted in Tech area also.
Ok, Ive seen post before about the battery going dead after a week or two of not driving.
However, I started vette fine this am. Looked at DIC and it showed 14.2 volts. So figure all is ok. Back it out, rinse off, dry, put on coat of polish and go to start. Clik, click, click. Will not start.
I too have had this happen when I have not driven for awhile, but this is the first time this has occurred right after it started ok and then an hour later dead! Whats happening???
Optima Redtop is only 2 yrears old.
Old Apr 15, 2006 | 04:14 PM
y2kcorvettebob's Avatar
y2kcorvettebob
Check and clean your battery connections
Old Apr 15, 2006 | 04:52 PM
Byfaithman's Avatar
Byfaithman
So clearly no power anywhere heh?
Old Apr 15, 2006 | 05:53 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
It showed 14.2 volts after the car started? That's the alternator charging the battery. Try reading the voltage before cranking the engine. If it's below 11.75 you need a new battery. Good luck with it. A battery is a cheap fix if that's your problem.
Old Apr 15, 2006 | 07:48 PM
JH's Avatar
JH
To Strange - Car will not start
