Stubborn shift knob
Old Apr 17, 2006 | 01:18 PM
gregandcallaway's Avatar
gregandcallaway
Default Stubborn shift ****
I puchased an aftermarket Hurst shift **** to put on my 2000 6-speed. There is a pin in the stock shifter that has to be removed before the stock shift **** can be removed. My son and I have yanked and pulled on this pin with vise grips, but to no avail. My question is simply this: how big a gorilla do I need to remove this pin? (Other hints would also be appreciated.)
Old Apr 17, 2006 | 05:34 PM
Hammie's Avatar
Hammie
This is the demon key. Search demon key and you'll see you are a typical vette owner having trouble with a typical vette problem.
When I took mine out just about 5 days ago, I tried pulling on it with vice grips and everything, but I eventually found that with a sturdy flatblade screwdriver, and prying from underneath the side (there's a ledge underneath if you look closely for the screwdriver to get under and push up against), it will pull up without much force. I put a rag over the **** when prying up, so the screwdriver would not ruin it. Use it like a mini crowbar.
Old Apr 17, 2006 | 05:58 PM
scottydog's Avatar
scottydog
Try a bottle opener to leverage it out.
Old Apr 17, 2006 | 06:04 PM
sage666's Avatar
sage666
Get a free paintcan opener from Lowe's, Home Depot, etc. It has a curved lip on it which fits under the small side ledge. Gently press down and the demon key slides right up and out. I've used the opener many times and it has worked every time.
A word of caution about vicegrips - while wonderful tools, if clamped too tight, the key metal can be damaged and if clamped too loose, the tool will slip off, go straight up, and damage the mirror, roof fabric, and, if you were really putting your back into it, dent the metal roof or break the glass top. Even putting a convertible top down first will not prevent SOMETHING from being damaged (like your hand/wrist/arm, etc).
Old Apr 17, 2006 | 06:13 PM
Richie Carbone's Avatar
Richie Carbone
DYNAMITE!!!!!!!!!
Old Apr 17, 2006 | 07:15 PM
StealthZ06's Avatar
StealthZ06
I just replaced my stock **** with a C6 **** and I had the same problem. I even got my father to try to yank it out (he's a big guy) and he pulled on it until he was red in the face. It didn't budge one inch. Finally we used a screwdriver for leverage and it popped right out. That thing isn't going to come out by just pulling on it.
Old Apr 17, 2006 | 07:24 PM
VatorMan's Avatar
VatorMan
CI 6-7-8 Veteran
St. Jude's Donor '06-'10-'11, '15
Another vote for the screwdriver.
Old Apr 17, 2006 | 10:12 PM
BAD_TCR's Avatar
BAD_TCR
Another easy way if you havent gotten it out yet..... drill a very small pilot hole into the key. Screw a small screw into that pilot hole. Grab a hammer, and flat piece of wood or metal as a base and use the hammer claw to fulcrum out the key.
Old Apr 17, 2006 | 10:14 PM
Miguels's Avatar
Miguels
it is difficult...I think I was lucky since the dealer had gone into my console before and had pry'd it out before.
I used the vise grips
Old Apr 18, 2006 | 12:15 AM
masksqueeze's Avatar
masksqueeze
Well be careful at what ever method you choose. I used a flat blad screw driver and as I was trying to pry it out with all my might the damn blade slipped and the handle of the screw driver put a nick in the damn radio.
Old Apr 18, 2006 | 09:17 AM
KMeloney's Avatar
KMeloney
Still in there? Clamp some VICE GRIPS tightly onto the key. Then, protecting the **** with a towel, using a block of wood atop the ****, leverage the vice grips upward with a heavy duty screwdriver. Pull upward on the vice grips with one hand, and leverage the mouth of the vice grips with the screwdriver with the other hand.
-Kirk
Old Apr 18, 2006 | 12:18 PM
dunbindun(tov)'s Avatar
dunbindun(tov)
I tried unsuccessfully with the above methods managing only to chip hunks of metal from the demon key. My solution: small vise grips, but first get a 6-8 in bolt to replace the adjusting screw (1/4-20 in my case). Before inserting the bolt slip it through a flat washer & as big a socket as you can fit. You now have a slide hammer. Tighten vise grips on the key as tight as you can and pull the socket sharply upwards (in an obscene manner) a couple of times. Key will now pop out. Works better with extra hand
DBD
Old Apr 18, 2006 | 03:34 PM
Dave68's Avatar
Dave68
The best way I've found is to duplicate an impact driver/jackhammer - works every time:
Old Apr 18, 2006 | 05:50 PM
Take a pair of vice grips, clamp them down on the top of the key, then gently tap up on the side of the vice grip until the key pops out. Worked very well when i did mine.
Old Apr 18, 2006 | 09:19 PM
mitchmark's Avatar
mitchmark
I used a small set of vise grips, a 9" piece of wood and a long heavyduty screwdriver. Check out my website for the details. It works great.
http://temp.corvetteforum.net/c5/mar...Pictures.shtml
Old Apr 18, 2006 | 09:49 PM
craig04c5's Avatar
craig04c5
This is how I got mine out except I used a pair of small channel locks which are like pliers but offset so you can tap the side upward with a hammer!
Old Apr 18, 2006 | 09:55 PM
Vette45's Avatar
Vette45
I used the vice grip and hammer method and it worked great!
To Stubborn shift knob
Old Apr 24, 2006 | 09:06 AM
gregandcallaway
Default Demon Key Removed!!
Thanks to everyone who replied. What worked for me was the vise grips and the hammer tapping upwards. The key slid right out and the new, white Hurst shifter **** is now in place.
Old Apr 24, 2006 | 09:15 AM
ORANGEBROTHERS's Avatar
ORANGEBROTHERS
Old Apr 24, 2006 | 09:39 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
http://www.vetteessentials.com/instr...t_install.html
This procedure will help.....
Thanks Ken!
