Welding ceramic coated headers??
Old Apr 17, 2006 | 05:34 PM
lococo's Avatar
lococo
5th Gear
Default Welding ceramic coated headers??
I have FLP full length ceramic coated headers, and a weld has broken where the header bolts to the frame. Needless to say it sounds like hell. I will replace them sooner or later, but I just need it fixed for the time being. Does anyone know if it is possible to weld when they are coated in this way? Thanks for any help
-Ryan
Old Apr 17, 2006 | 06:14 PM
sage666's Avatar
sage666
Maybe ceramic slurry and a gas torch but I sure would not try it without having the header locked in a jig. You can't get the car back to the place that installed the headers?
Old Apr 17, 2006 | 06:20 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Just grind around the area to be welded (to remove the coating - standard prep for any weld job), weld it up, then spray it with some hi-temp paint to keep it from rusting. The FLP's are mild steel, and without any coating, will rust very quickly.
Old Apr 17, 2006 | 06:23 PM
sage666's Avatar
sage666
Much better answer than mine!
Old Apr 17, 2006 | 08:40 PM
Patches's Avatar
Patches
Here's a pic of two auxillary bungs, left and right, welded onto my right FLP header. The left is for a WB O2 sensor and the right is for an exhaust temp sensor.
Here's a shot of my FLP x-pipe where I had dumps for QTP cutouts welded on. I painted the rear section with ceramic high-temp paint after the welds were done.
Old Apr 17, 2006 | 10:16 PM
edensknight's Avatar
edensknight
Excellent, Patches! Great pictures. Thanks for sharing, brother!
Old Apr 17, 2006 | 11:22 PM
lococo's Avatar
lococo
5th Gear
really appreciate all the help guys.
To Welding ceramic coated headers??
