rear defogger
Old Apr 17, 2006 | 08:47 PM
doug doo wop's Avatar
doug doo wop
Default rear defogger
I noticed while cleaning the inside of the rear window that one of the wire connections came broke off. I tried to pry open the connector and to stick the wire back in, but no luck. Anyone have this problem and how was it fixed, self or dealer. I do have an extended warranty and I wonder if it would be covered? Thanks
Old Apr 18, 2006 | 12:44 AM
Badbee's Avatar
Badbee
Default Rear Defogger
My 04 Z06 has the same problem. Two dealers advised they would not cover under warranty since it was broken rather than a defect?? They also advised the rear window would have to be removed to fix or totally replaced. I used black electrical tape to hold it together. You can't really see the tape unless you look for it. Actually, I really don't have the need to use a defogger very often here in California. Try the tape, let me know what you think. Dennis
Old Apr 18, 2006 | 01:07 AM
doug doo wop
Thanks for the info.
To rear defogger
