Cant get jacking puck out!!!
Old Apr 18, 2006 | 08:12 PM
FLYNAVY30's Avatar
FLYNAVY30
Default Cant get jacking puck out!!!
Just noticed drivers side front has 1 jacking puck stuck in it....cant get it out. Its not the metal type that you typically see.....its hard plastic, and the bottom is about a 2 inch by 2 inch pad. How the hell do I get this thing out?? Ive tried prying, pulling, and twisting....wont budge....kinda spins, but wont come out. Any suggestions?
Old Apr 18, 2006 | 08:27 PM
CUlookin's Avatar
CUlookin
Twist harder!
I've had my metal ones from EE stuck before and it just took some muscle to get it to rotate... I'm sure you've got more than enough strength! Other than that, I guess just add it to your mod list!
Old Apr 18, 2006 | 08:40 PM
vertc51116's Avatar
vertc51116
From: Mustangs are like Tampons.. Every P*$$* has one!
HAMMER!!
Old Apr 18, 2006 | 08:53 PM
kvozel's Avatar
kvozel
From: Centerville OH "If we weren't all crazy we would go insane"
CI 3-4-5-6-7 & 9 Veteran
St. Jude Donor '08
K-Y Jelly (and personal lubricant!)
Old Apr 18, 2006 | 11:18 PM
FLYNAVY30's Avatar
FLYNAVY30
1.) guess ill try again
2.) hammers + fiberglass scare me
3.)I love my car...but not quite that much
Old Apr 18, 2006 | 11:19 PM
mechryn's Avatar
mechryn
Go smoke the tires a bit. It will fall out...
Old Apr 18, 2006 | 11:34 PM
Dave68's Avatar
Dave68
You might want to use a Dremel tool to cut it down the middle. You should ten be able to pull it apart until you have just a plastic shaft. Then, drilling it out would be a possibility. Of course, this is a last resort type of suggestion, but sometimes, you have no other choice.
Good luck!
Old Apr 19, 2006 | 01:32 AM
SLPRC5's Avatar
SLPRC5
Put it on a jack stand. Use a drill bit down the center. Or a chisel like mentioned.
Old Apr 19, 2006 | 03:00 AM
sebringsilver97coupe's Avatar
take it to your dealer, they can tear up anything.
Old Apr 19, 2006 | 03:43 AM
mhdi22's Avatar
mhdi22
Sounds like it's pipe wrench time.....
Old Apr 19, 2006 | 03:51 AM
SLPRC5's Avatar
SLPRC5
Originally Posted by vertc51116
HAMMER!!
TIME
Old Apr 19, 2006 | 05:04 AM
Pizzano's Avatar
Pizzano
Leave it in there , then you wont have to install it next time you need to jack the car
Old Apr 19, 2006 | 06:51 AM
How true that is.
Old Apr 19, 2006 | 07:31 AM
rwsr50's Avatar
rwsr50
Look on MidAmerica Motor Works site. They sell plastic ones that sound like what you are describing that snap in and can be left in place. They have a picture of one that shows 4 projections that spring out and lock into the hole. By looking at the picture and seeing how they work, you will be able to figure out how to remove it. Seems like you'd want to push the projections toward the center to get by the catches.
It's harder to write than to do probably. Check out that picture. http://www.madvet.com/shop?frame=2.66.2920
Old Apr 19, 2006 | 10:58 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Sad but true
To Cant get jacking puck out!!!
