99 Coupe Engine Swap LS1:LS2
Old Apr 21, 2006 | 07:33 PM
Crash01's Avatar
Crash01
8th Gear
Default 99 Coupe Engine Swap LS1:LS2
An opportunity came about for me to swap out my LS1 for a brand new LS2 motor and I figured I'd change the 3.15's to 3.42's while I was at it. The diff is also brand new and it is a complete unit, not just gears. I currently sport the B&B Route 66 Cat Back with oval tips (awesome tone BTW). I wanted to do headers with X-pipe, but funds ran low. Maybe later. Regardless, the difference from my old set-up to the new set-up should be rewarding. This is my DD so I don't want to get too radical with it.
Question: Has anyone heard of a Special/Limited Edition LS2 pushing 446 hp opposed to the standard 400 hp? I can't find anything on such an animal and figured I'd throw it out there. I'll let you know how this thing turns out and how pleased I am with the results.
Remember the Vette Wave:
Old Apr 21, 2006 | 08:49 PM
Vette45's Avatar
Vette45
Sounds like a good deal - too good of a deal!
I'd find out the specs and history of the LS-2!
Good luck!
Old Apr 22, 2006 | 12:36 AM
Crash01's Avatar
Crash01
8th Gear
I've order the motor and getting the work done from a reputable place that I normally go to. Got the rear end from an awesome cat from CF, "Indianavette". Super friendly guy with awesome customer service.
Once I get more specifics on the motor I'll post. Hopefully I'm not talking out my back side passing bum scoop.
Old Apr 22, 2006 | 01:02 AM
slammedwhitec5vert's Avatar
slammedwhitec5vert
Old Apr 22, 2006 | 01:03 AM
Frizzle86's Avatar
Frizzle86
In the GM High Tech Preformance Magazine
They did an engine dyno test on the LS2 with a base line run (with a .5HP) for their testing. It was recorded at 402.1 which sounds good to me
They also did some different cam setups and came up with some impresive numbers They added a "stage 1" cam (with out head change)with 218/220 @.50 .570 lift (114 lobe separation angle) and they got about 90 more HP out of the LS2.
But no I've never heard of a special edition/ limited edition from GM.
Old Apr 22, 2006 | 01:05 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Mid America Limited Edition ZL465 Package
Get 465 horsepower from your LS2 with bolt-on parts!
Take the guesswork out of upgrading your 2005-06 C6 Corvette, with the Limited Edition ZL465 PerformancePac™ from Mid America and SLP Performance Parts. Each 465 horsepower package includes our cold-air induction, complete header to cat-back exhaust system, thermostat, custom PCM tuning, and high ratio 1.85 rocker arm package, all of which work together to significantly improve performance without adversely affecting drivability.
Each Limited Edition ZL465 PerformancePac includes the following items:
Blackwing™ Induction System
PowerFlo™ Cast Quad Tip or Dual Outlet Exhaust System
SLP Custom Tuning
160º Thermostat
1.85 Rocker Arm Package
Long Tube Ceramic Coated Headers
Header Installation Kit
Header Down Pipes
High-Flow Cats
PowerFlo-X™ Crossover Pipe/Balance Tube Assembly
ZL465 Fender Badges (pair)
Center Console Cushion w/kit # & ZL465 Emblem
Custom Perfor-mats w/ZL465 Emblem
Door Pull Wraps w/kit# & ZL465 Emblem
Door Jamb Badges w/kit # & ZL465 Emblem with signatures of both Ed Hamburger & Mike Yager
Letter of Authenticity w/kit # and signatures of both Ed Hamburger & Mike Yager
Click here for more information and ordering 1 of 100 Limited Edition ZL465 packages through
Old Apr 22, 2006 | 01:43 AM
Crash01's Avatar
Crash01
8th Gear
Awesome feedback. I'll let you know exactly what I'm working with when I get the info.
Old Apr 22, 2006 | 08:45 AM
BiggieBoy's Avatar
BiggieBoy
Hummmmm. This install will be interesting. Keep us posted and good luck....
Old Apr 22, 2006 | 02:48 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
St. Jude Donor '05-'06-'07
...sounds interesting...
Do you just want an LS2??
...couldnt you get the hp/performance without the swap...?
Old Apr 23, 2006 | 09:11 PM
Crash01's Avatar
Crash01
8th Gear
Absolutely, but I messed up my LS1 and figured I'd replace it with LS2. Long story, too ashamed to talk about it.
Old Apr 23, 2006 | 11:04 PM
GOZ2FST's Avatar
GOZ2FST
No shame allowed on this forum.
I'm actually waiting for the day my LS1 gives up the ghost - and I will move to an LS6. Prolly should buy one now and put it in the garage.
But I know for a fact there is an LS6 to LS2 conversion kit - I've seen the bags of cables with these markings on them.
Why go from an LS6 to an LS2? Saw it happen on a Z06.
Because a crate LS7 was hard to come by.
And, they put new heads on - so with a 6 liter motor, they were looking for 500+ HP.
Of course, I assumed there was some money involved.
To 99 Coupe Engine Swap LS1:LS2
