Corsa Exhaust
Old May 29, 2006 | 10:01 AM
KidCid's Avatar
KidCid
CI 7-8 Veteran
Originally Posted by mcgraziano
I have the Corsa Pace Car with pro tips and no X-Pipe in my C5 w/ an A4. I also have the motor boat sound and poping on deceleration. I dont mind the poping too much but the boat motor has to go. The poping has a lot to do with the way you down-shift. If I down-shift from highspeed to a lower gear, generating high RPMs (Lots of engine/compresion braking) the poping is more pronounced. I am planing on an X-Pipe to hopfully mute the boat noise.
Yes, the X-pipe will fix the problem for the most part. You get rid of the unever motor boat sound and most of the popping. But every once in a while the popping is still there, especially if you shift the A4 and let the engine handle the load.
Old May 29, 2006 | 01:37 PM
mcgraziano's Avatar
mcgraziano
Thanks for the info, I'm fairly sure the X-Pipe is my next mod.
Does anyone know if all X-Pipes are created equal in eliminating the "Boat" noise and most of the "Poping" with the Corsas? I did notice the Corsa X-Pipe is some what different then Bassani's version.
Old May 29, 2006 | 01:53 PM
phoenixfoundmac's Avatar
phoenixfoundmac
I've got the Indy's and the Corsa X-pipe. I don't think it has much of a motorboat sound at all. The popping is still present, but it's minimal and you almost have to induce it. As far as the various x-pipes available I will say that when I got my Corsa X-pipe I examined it and comparing it to other brands (bassani for instance) the crossover connection seems to be smaller on Corsa's which would indicate a lesser ability for the gases to mix. But Corsa claims that their x-pipe is tuned to their cat backs so I suppose it is cut to that size for optimal performance. I think you will be overall pleased with the Corsa x, but if you could get some input from somebody that has another brand with their indy's that would be great.
