flush mount tail lights
Old May 15, 2006 | 10:02 PM
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
attached mine to the lights.
And I have have 2 back themselves out in the past year. Might consider light duty thread lock or even white glue on the threads just to ensure a solid fit.
Old May 15, 2006 | 10:04 PM
RainJ's Avatar
RainJ
btw, Barnee's post should be a STICKY if its not already!
Old May 16, 2006 | 01:28 AM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
Originally Posted by BarneePhife
Here are pics I took during my DIY install.
Excellent step by step procedure and pictures to go along with it. Your pics have given me the confidence to try it. Thanks again for the info.
Old May 16, 2006 | 01:59 AM
460HP-YLO-JAKT's Avatar
460HP-YLO-JAKT
Originally Posted by Willfulone
To the light assembly, where the red lense meets the housing...
Peace
Willfulone
Old May 16, 2006 | 10:41 AM
tlong72's Avatar
tlong72
I have been reading this forum for 6 months or so, just joined this month as I am now ready to buy my first vette. I have read a ton of post that had smart-*** comments and other comments that are detrimental to the forum. This is one post that I am saving and plan on doing this to my Vette the day I get it. Looks great! Great informational post.
Old May 16, 2006 | 10:47 AM
BarneePhife's Avatar
BarneePhife
St. Jude Donor '07
Thanks to everyone who has made kind comments regarding my pictures. I'm happy to hear that so many others value this type of information. I'll definitely keep it coming as I do more projects in the future.
Old May 16, 2006 | 10:56 AM
sgtzim's Avatar
sgtzim
St. Jude Donor '11
Originally Posted by free C-5
I like your kit much better, also do you have any problems with the light moving, like its not mounted solid
I did mine last weekend with the same system as Barnee used. I have a little bit of a "rocking" problem, but only when I physically push on the bottom half of the light (I noticed it when I washed the car). The light does not move with normal driving though.
Old May 16, 2006 | 11:40 AM
BarneePhife
St. Jude Donor '07
Hmm... it shouldn't rock. It sounds like you may not have one of the screws in far enough. I'm sure you've tried tightening both, careful not to strip anything? Try this... Loosen both screws, then try to jiggle the light and push it futher back into the recess if possible, then tighten the screws down. On my lights, the weather stripping forms such a tight seal that mine don't move even if I take the screws out to remove the light.
Old May 25, 2006 | 03:33 PM
HollywoodFRC's Avatar
HollywoodFRC
Default Additional Tip - Flush Mount lights
My first mod to my '99 FRC was the flush mounted tailights using parts recommended from Lowes method. The spacers provide, obviously, the necessary spacing, the Foam provides the stability since it sits between the light and the opening. Press the lights into position while tighteneing the screws by hand. Once set in place, the light won't move. Here's a tip, to keep the spacers from sliding off the screws during install, put a piece of electrical tape over the spacer hole and wrap it around the spacer. Place the screw in the light and slide the spacer over the screw poking through the electrical tape that you put over the spacer hole. Now the spacer stays in place and won't slide off during installation. Installation goes really fast that way.
Old May 25, 2006 | 08:10 PM
KARSC5's Avatar
KARSC5
Great post!!
Old May 26, 2006 | 08:46 AM
nickolbag's Avatar
nickolbag
If possible does anybody have a close up pic on a light after the install? I just want to see what the weatherstrip around the light looks like close up. Im thinking of doing this but I have heard that the weatherstrip makes it look "cheap". Thanks
Old May 26, 2006 | 11:32 AM
BarneePhife
St. Jude Donor '07
I should have some on the home PC. I will post a couple tonight if I've got them.
Old May 26, 2006 | 11:52 AM
  #33
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
I like this post if for no other reason, than to show people they don't have to purchase a pricey "tail light seal" from the vendor thread that just never seems to disappear.
I prefer the recessed factory look, however, for the sake of adademics I do have a question: By pushing the tail lights out, you are also pushing the bottom farther out than the tops of the light attemblies in order to achieve the flush look, or are you? I would be concerned that the reflectors in the lenses would be less effective by setting the lights at an angle like that.
Old May 26, 2006 | 12:00 PM
  #34
BarneePhife
St. Jude Donor '07
When I did mine (and I think maybe my pics illustrate this), the lights seem to actually stay at the same angle. The top of the lights sticks out a little further past the rear fascia than the bottom of the lights due to the curve of the fascia.
However, I have seen someone else's pic where they somehow appear to have tilted the lights so that they more closely match the curvature of the fascia. In that case, I would agree with your concern that the reflectors in the lenses could be prone to being less effective.
Old May 26, 2006 | 12:17 PM
  #35
danberry's Avatar
danberry
Excellent write up with pics........did the flush mount last week and noticed that the one way of doing it was to use Frost king foam weather strip........did that first...then noticed that BarneePhife actually used Md Specialty Marine and automotive vinyl weatherstrip...Took mine back out and used the Md stuff....very nice look....took more of a forcing to get the lights in but they don't move and look very good and professional.........thought the foam might wick and hold water.......???????????? Thanks again BarneePhife
Old May 26, 2006 | 12:35 PM
  #36
garymilgrom's Avatar
garymilgrom
Default You cannot see the foam
I did this last weekend - an easy one hour project. You cannot see the foam past the lights, so I don't see how it could look cheap. And the angle of the light seems unchanged, the top still sticks out a bit more than the bottom, like stock. And don't forget to paint the screws black! Here are some of my photos:
Old Jun 14, 2006 | 01:59 PM
  #37
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Well, I am getting ready to do mine, I will post pics of results when I get finished. Hope this comes out as good as the others.
Micah
To flush mount tail lights
Old Jun 14, 2006 | 03:53 PM
  #38
rtagz's Avatar
rtagz
Cruise-In IX Veteran
can anyone tell me where to get that md weather stripping, in nj i can't find it anywhere, the company (MD) only has 2 places it sells to here, and i can;t seem to get ahold of them.
Old Jun 14, 2006 | 04:57 PM
  #39
j99vette's Avatar
j99vette
i did the conversion over the weekend and i couldnt find it either. i couldnt find any in black at lowes. they had white and brown. i got the brown and mounted it to the bumper instead of the light. works just as well and the light covers up all of the weather stripping.
Old Jun 14, 2006 | 05:22 PM
  #40
jedicowboy's Avatar
jedicowboy
I mounted my weather stripping to the fascia as well. I tried over and over to use the md stripping on the light as shown in Barnies post. It was a bear to fit it in and impossible for me to get it even looking once I finally got the screws to take. I worked for an hour or two on one light.
I ended up just putting the md right inside the opening and putting the lights in with the extended screws and spacers. I looks good and you can't see any of the weather stripping. 20 minute job.
I just did this last night so I really have not had time to decide if I like it or not. I initially do, but would rather have a seal of some sort around the edge of the lense. I might try again with some thinner stripping
