flush mount tail lights
Old Apr 23, 2006 | 08:27 PM
free C-5's Avatar
free C-5
Default flush mount tail lights
I am installing the "LOWES" flush mount tail light kit and was wondering which do you affix the weatherstrip to, the rear fascia or the back of the tail light itself. thanks for any help and or tips.
free C-5
Old Apr 23, 2006 | 09:28 PM
slammedwhitec5vert's Avatar
slammedwhitec5vert
I did mine to the rear facia.
Old Apr 23, 2006 | 11:04 PM
debmwb's Avatar
debmwb
I did mine to the light assembly.
Old Apr 23, 2006 | 11:07 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
To the light assembly, where the red lense meets the housing...
Peace
Willfulone
__________________
..................Click for
Old Apr 23, 2006 | 11:48 PM
460HP-YLO-JAKT's Avatar
460HP-YLO-JAKT
Peace
Willfulone
Old Apr 24, 2006 | 12:03 AM
edensknight's Avatar
edensknight
Great tip!
Old Apr 24, 2006 | 01:53 PM
powderski13's Avatar
powderski13
Peace
Willfulone
I also had to trim the weatherstrip to get it to seat good.
Old Apr 24, 2006 | 02:49 PM
C5forFun's Avatar
C5forFun
Where do I find info on this? Pictures, type of weatherstrip, etc. I would like to seal the bucket too, I get road spray in from the back where the wiring goes thru.
FOUND IT IN ANOTHER THREAD
Old Apr 25, 2006 | 10:30 AM
BarneePhife's Avatar
BarneePhife
St. Jude Donor '07
Here are pics I took during my DIY install.
Old Apr 25, 2006 | 03:15 PM
C5forFun's Avatar
C5forFun
Very nice! Thanks for the pics. My only concern is how do you keep the area behind the lights from filling up with dirt, road spray, etc. kicked up from the back side? Now that it is sealed around the light it won't get rinsed when you wash the car.
Old Apr 25, 2006 | 04:38 PM
BarneePhife
St. Jude Donor '07
Don't ask me! I can't see that area unless I take the lights out.
I don't worry about what's behind the light. It's probably filthy, but who will ever see it?
Old Apr 25, 2006 | 05:20 PM
free C-5's Avatar
free C-5
I like your kit much better, also do you have any problems with the light moving, like its not mounted solid
Old Apr 25, 2006 | 07:29 PM
poolhustler's Avatar
poolhustler
Thats a nice install, but please put low tack blue painters tape on the bumper so nothing gets scratched by the lights.!!
Russ...
Old Apr 25, 2006 | 09:13 PM
BarneePhife
St. Jude Donor '07
Russ...
Thanks for the tip! I didn't have any handy at the time.
-Jim
Old Apr 25, 2006 | 09:16 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Nice install post. I personally like the original look, but your write and pics make things worth-wild on doing it.
Micah
Old Apr 25, 2006 | 09:17 PM
BarneePhife
St. Jude Donor '07
I have not had any problems with any of the lights moving. You must use 2" long screws to reach through the nylon spacers into the factory holes in the car - otherwise I'm sure it either wouldn't thread, or a screw might even back itself out with vibration from driving. But with the 2" screws in all 8 holes, it's not been a problem for me. (knock on wood) I've had mine flush mounted since March 4th of this year and no problems.
-Jim
Old Apr 25, 2006 | 10:52 PM
mredden05's Avatar
mredden05
Great looking installation ! ! ! What size spacers did you use and where did you get the weatherstrip?????
To flush mount tail lights
Old Apr 25, 2006 | 11:15 PM
CCA Corvette Parts
This is how I did it...
(6) 1" L X 1/2 W X .194" Hole Size Nylon Spacers
(6) 1/4" L X 1/2" W X .194 Hole Size Nylon Spacers
(8) #8 x 2" Zinc Pan Head Screws
(1) Frost King Rubber Foam Weatherseal 3/8" W X 5/16" Thick x 10' Long (Adheasive backed)(I got the black weather stripping)
Simply unscrew tail lights, clean, put weather stripping around the tail light (where the red casing meets the black casing of the light) insert new screws and spacers on back side, screw back into mounting hole.
-The two center lights get one 1" spacer on each screw.
-The outside lights get three 1/4" spacers on each of the outer most
screw
-The inner screw on the outside most lights get one 1" spacer.
-Fit so the weather stripping looks good and screw them back in!
1" spacers $4.77
1/4 Spacers $3.42
Weather stripping $3.98
Pan head screws $.98
Peace
Willfulone
Old Apr 26, 2006 | 07:55 AM
BarneePhife
St. Jude Donor '07
screw
Peace
Willfulone
That's pretty much what I used/bought, execpt my Lowes had 3/4" long nylon spacers, so I didn't have to stack up three 1/4" spacers.
-Jim
Old Apr 26, 2006 | 08:37 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
St. Jude Donor '03 thru '20
Jim,
Nice post. I did the DIY method over 1 year ago and they are hanging in there fine.
Thanks for the step by step version.
