MS3. PRC LS6 heads, underdrive pully, fast/ls2 tb Kooks long tubes and x-pipe threw B&B RT 66 mufflers.
The car is pretty quite with the cam here is a clip.
Yes this is the head and cam that Steve and i installed. Cam specs are 237/242 603/609 113 lsa. This was corrected numbers threw the B&B rt 66 and 1 3/4 headers witch are killing power but keep it quite. I also have stock 10.5-1 compression and the tune isn't to agressive because I plan on adding a bottle to her next week.
Just want to say thanks to the guys at TSP, Dez racing and Conn. Enjoy.
Interesting graph...If it were me, I'd take the lower HP tune in favor of the higher torque. It seems like you lost a lot of area under curve in the pursuit of horsepower.
Either way though, very nice numbers. I'd also like to know the mods.
Nice numbers turbo1k How is the everyday driveability? I assume your car is a 6spd. Can you cruise at 65 or 70mph in 6th without any surging or bucking. I have been thinking of the Torquer 2 from TSP or their 228/228 cam with the same heads you are running but I don't want to give up "cruiseability" if you know what I mean. I also have 3.42 gears and my car spends alot of time at 70mph which is around 1500 rpm. The MS3 was bigger than I wanted to go but if the driveability is good, I would reconsider. Thanks for your input and I hope you enjoy your new power.
After i had the tune done today she drives 95% like stock but before she had some problems with cruising. As far as 70 in 6th goes i'll check tomorrow, i usually cruse at 75-80 and had no problem. If you are in the MA/Ri or at one of the CT meets i'll be more than happy to let you drive her.
