Corsa Exhaust Pro Tips
Old Apr 26, 2006 | 02:42 PM
c5coast's Avatar
c5coast
Default Corsa Exhaust Pro Tips
Yesterday I had the corsa pace cars w/Pro tips installed. While the installer took his time leveling the tips I notice a slight angle (toe-in) to the middle on each set. For me It's noticable, I imagine if I throw a straight edge across the face of the tips it'll be even more apparent. Is this normal or do they need additional tweaking. Anybody else have this problem?
Old Apr 26, 2006 | 02:45 PM
ORANGEBROTHERS's Avatar
ORANGEBROTHERS
Some Borla Stingers have the same problem. Not real noticable though unless you get crazy and start running stright lines.
Old Apr 26, 2006 | 02:56 PM
c5coast's Avatar
c5coast
During the install I took a look while the car was on the lift and the installer said that because of the different angles the rear throws he puts the car on the ground and checks alignment from 30' back. Seemed reasonable and the tips are level just when looking closer they appear to point in.
Old Apr 26, 2006 | 03:03 PM
ORANGEBROTHERS
If your not happy with it make him fix it or take it someplace else and get it aligned however it looks best to your eye.
Old Apr 26, 2006 | 03:11 PM
MikeeVet's Avatar
MikeeVet
I had same problem with my corsa pro tip the installer readjusted them for me and tacted a weld on claps been good so far ...
MikeeVet's Avatar
MikeeVet
Old Apr 26, 2006 | 03:15 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I adjusted mine after a month or so... nothing huge... just a slight alignment...
BTW, were you at Hooter's on Sunday?
Old Apr 26, 2006 | 05:37 PM
c5coast's Avatar
c5coast
Yep I was at hOOters...We spoke about your strobes for a few minutes. I had the other MRII similar to Chris's but without the chrome insets.
Old Apr 26, 2006 | 05:47 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old Apr 26, 2006 | 06:38 PM
BELVIN20's Avatar
BELVIN20
I got the Corsa Pro Tips on my 2000 Vert, have a heck of a time getting them aligned, Corsa even sent me a new Drivers over the axle pipe, did not fix alignment problem, next they sent me a new muffler, still did not fix the problem. Finally I took the car to an exhaust shop who took the over the axle pipe and put it on a pipe bender and took some of the bend out and finally got the tips even, also tack welded everything to keep it in place. Muffler guy told me just about all aftermaket systems he has installed need some sort of tweeking the get them right. He notes that all cars are just enough different that alignment issues are always a problem.
Old Apr 26, 2006 | 09:28 PM
love my car's Avatar
love my car
Yea my corsas had me going nuts had them send me another left side still is SLIGHTY of but im ok with it.Take a look at myhttp://img.photobucket.com/albums/v729/kharrin/corsaindys3.jpg
To Corsa Exhaust Pro Tips
