transmission problems?
Old May 2, 2006 | 06:37 PM
deputy_dog1192's Avatar
deputy_dog1192
Default transmission problems?
Just curious what would be causing my shifts not to be smooth. Yes, I push the clutch all the way to the floor. Sometimes it acts like it doesn't even want to go into R. From time to time I have problems getting into 1st. When I'm moving, shifts into 2nd and 3rd seem rough. Any ideas, anyone else experience this?
Old May 2, 2006 | 06:45 PM
astrolite's Avatar
astrolite
I'm not a mechanic, but I've dealt with this before. It sounds like a hydraulic issue. It could be a slow leak in one of the cylinders
(most likely the slave cylinder if you are still using the older type) letting air get in. Does your clutch ever feel like it is sticking a bit?
If it goes real south it is pretty easy to diagnose. Clutch will stick a lot, sometimes all the way to the floor.. getting in gear becomes near impossible.
Old May 2, 2006 | 06:48 PM
deputy_dog1192
Default .
Haven't noticed the clutch sticking to the floor. Could I just need to drain the tranny fluid and put new in? Car is an '02 with 28K on it.
Old May 2, 2006 | 08:39 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I have an '02 and this last winter I bleed the clutch. Man what a difference. And you wouldn't believe the crud that came out. While in there I installed the LAPD remote bleeder so that I never have to take the exhaust and tunnel plate off again to bleed the clutch. Last year I drained and refilled the tranny and that to made a nice difference. Also when I do that again I'll be putting in synthetic fluid. Hope that helps out. If your a do-it-yourself kind of guy and want to install a remote clutch bleeder let me know I'll probably be able to save you a few hours with the install.
Old May 2, 2006 | 10:20 PM
deputy_dog1192
Default .
Thanks a lot stock man, that helps. And I'm definately NOT a do-it-yourselfer! Thanks anyway.
To transmission problems?
