Low Voltage
Old May 3, 2006 | 06:30 PM
99vettish's Avatar
99vettish
Default Low Voltage
This is my first time on the forum. I have a Low Voltage message and a clicking noise on the passenger side floor. Car will not start. Help me please! Is this a bad battery or some else?
Old May 3, 2006 | 07:05 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Have you tested the battery??????It's the first thing to do
Old May 3, 2006 | 07:08 PM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
Test the battery if possible. However, if you are hearing the clicking noise(starter solenoid), your battery is too low to start and should be replaced or recharged, then get the charging system tested. If the alternator is also bad, you will drain your battery again and the vicious cycle will continue!
To Low Voltage
