Trunk lid liner
Old May 8, 2006 | 03:43 PM
Baron138's Avatar
Baron138
Default Trunk lid liner
My trunk lid liner keeps falling down now. The velcro tape isn't cutting it. I am thinking about trying to screw it with short screws to the ribs of the trunk lid. I figure it wouldn't take many. It would be just to assist the tape. Has anyone else tried this?
Old May 8, 2006 | 04:14 PM
dndrsn's Avatar
dndrsn
http://forums.corvetteforum.com/show...ighlight=trunk
Old May 8, 2006 | 04:35 PM
tommybells's Avatar
tommybells
Used Silicone and it worked fine...2 years
Old May 8, 2006 | 04:50 PM
Vince Del's Avatar
Vince Del
Cruising
Be Careful.It cost me $500.00 to fix the hole in my trunk.The velcro supplied isn't worth a ____.The body shop that fixed my hole used their own formula,and now looks great. You may want to try silicone as suggested.
Old May 8, 2006 | 05:26 PM
DeeGee's Avatar
DeeGee
The link above is my DIY Liner.
I had the same problems so I drilled 4 holes for the studs in the V Beam. It now holds on nice and tight. I got the studs at Autozone.
Just be very careful not to push too hard on the drill and come through the trunk lid.
Old May 8, 2006 | 09:50 PM
CAR Motorsports's Avatar
CAR Motorsports
A TLC may be securely fitted using a proper tape holding system. We supply our C5 TLCs with a two part tape system for worry free mounting and easy removal if so desired. You are welcome to call us tomorrow and we will be happy to help you with your problem.
Rich
CAR Motosports
To Trunk lid liner
