How do you get codes?
Old May 17, 2006 | 11:04 PM
Vassili's Avatar
Vassili
Default How do you get codes?
I tried what 1 forum member said to do. Press the fuel guage and hold, then press the options button 4 times. Got nothing for my "Service vehicle soon" message?
Old May 17, 2006 | 11:06 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Press and hold options and then press Fuel 4 times while still holding the options button you must do this quickly. A message will appear saying "Diagonstics" then it will automatically read off the codes. Like....02-PCM(No codes)....03-BCM(No Codes)...ect. if there is a code it will look something like this 02-PCM (1052H) NOTICE THE H at the end of the code, That represents a code that has happened in HISTORY. If there is a C after the code it is CURRENT. To clear the codes let it automatically cycle through the codes then it will come to (MANUAL DIAGNOSTICS) this is where you can clear codes. Use the options button to scroll forward and the TRIP to scroll backward find the code(s) to be erased like 02-PCM (2Codes). To erase this, press and hold the reset button until it says "NO CODES" There you have done it!!!. To exit the Diagonstic menu press the METRIC BUTTON!!!
Old May 17, 2006 | 11:16 PM
GrayC5's Avatar
GrayC5
Computer Codes and DTC Information
Old May 17, 2006 | 11:47 PM
Rogue Wave's Avatar
Rogue Wave
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
You got it backwards... options then fuel 4 times (within 10 seconds).
To How do you get codes?
