High Temp Paint
Old May 19, 2006 | 09:22 AM
Sako's Avatar
Sako
Default High Temp Paint
Painting my calipers next week. Is high temp paint necessary? On this forum some us VHT, 500F Duplicolor, Rustoleum, and body color Duplicolor. I am painting the rotor hats and caliper frame gloss black and the calipers red. The car is never tracked. I'll probably spray them since I am installing SS lines and the calipers will be off the car.
Old May 19, 2006 | 10:27 AM
rws.1's Avatar
rws.1
I just used Sunset Red from Rustoleum( not even high temp)... on my calipers. Has lasted a year now, no issues
I believe guys are using the high temp paint on the rotor hats.
Check for a post on the topic by Evil-Twin . I believe he used some 1500 degree clear for the hats.
Old May 19, 2006 | 10:33 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
For the calipers - many forum members have had great success with plain old Rustoleum. As far as the rotor hats, they might get hotter, but they should still be okay, since you aren't tracking the car.
My first go around, I painted my calipers myself with the G2 Folia-Tek kit that I got at Forum Vendor Xtreme Motorsports. It's a 2-stage epoxy that dries as hard as a brick. It's a brush on paint, so it isn't absolutely a requirement to take off the calipers.
Since then, I have had my calipers powdercoated. More expensive and look a little nicer, but if you take your time, apply several coats and mask off any areas that you don't want paint on - the results will be excellent!
Old May 19, 2006 | 10:35 AM
jrose7004's Avatar
jrose7004
I would think that the high temp paint would last longer. I used VHT on mine.
Old May 19, 2006 | 10:45 AM
barrynk's Avatar
barrynk
VHT for me also, just finished my install yesterday. Black for the calipers, clear for the rotor hats.
Old May 19, 2006 | 11:50 AM
DeeGee's Avatar
DeeGee
Rustoleum for me and no problems
Old May 19, 2006 | 12:31 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
I used Rustoleum on my C3's calipers. On the Rogue C5 I used genuine Dupont automotive paint (Mag Red Met II : primer, base coat, tint coat, clear coat).
No problems.
Old May 19, 2006 | 04:38 PM
Oldvetter's Avatar
Oldvetter
400-500 degree paint is okay for the calipers. You should use at least 1200 degree paint for the rotor hats and edges. Don't worry about masking off the rotor, the pads will clean the firepath quickly.
Old May 19, 2006 | 04:55 PM
BlueDream's Avatar
BlueDream
I've used the regual GM factory paint to match the color of the car (small spray cans from a GM dealer). Has worked great for me for three years.
Old May 19, 2006 | 07:54 PM
jman1's Avatar
jman1
i used engine enamel on mine..
To High Temp Paint
