my c5 needs lowered!!!
Old May 23, 2006 | 09:02 AM
c5vette_dallas's Avatar
c5vette_dallas
Default my c5 needs lowered!!!
where can i buy the kit to lower the front and back?
Old May 23, 2006 | 09:37 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Hi there, you don't need to buy anything. You will have to get an alignment. I found that out. Check out the link. I got longer bolts for the rear on mine and cut the front bushings to go even lower than the stock adjustment will allow.http://www.frankhunt.com/FRANK/hobbi...5_Lowering.htm
Old May 23, 2006 | 10:35 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i have also cut a portion of the front bushing and added longer bolts in order to go lower than what the factory adjustments allow.
just make sure you get that thing aligned afterward!
Old May 23, 2006 | 11:13 AM
jackj's Avatar
jackj
no need too, turn the 10 mil front bolts on top of shocks to right as far as they will go, rear cut rubber bushing in two, bolt back up leaving two treads.... put key back in..... done
Old May 23, 2006 | 12:07 PM
Bullet's Avatar
Bullet
Check out my signature - nothing cut, just cranked on the factory bolts. Keep in mind that I have 19" wheels and tires. It makes the car appear lower. If it is not low enough after letting the car settle, you could do some cutting then.
Old May 23, 2006 | 06:45 PM
C5-GIRL's Avatar
C5-GIRL
About time... That thing looked like a 4-wheel-drive when I saw it the other nite just kidding Bring it over here to Wiseman's - they'll fix ya up
C5-GIRL
Old May 23, 2006 | 08:14 PM
YO-EL's Avatar
YO-EL
Lowered on STOCK bolts.
NO bushings cut..
Old May 23, 2006 | 08:26 PM
VLVETTE's Avatar
VLVETTE
Lowerd on stock bolts
Old May 23, 2006 | 08:40 PM
Dark-Knight's Avatar
Dark-Knight
You got advice, do the job with stock bolts, you'll be happy with it!
Old May 23, 2006 | 09:05 PM
BltByKrmn's Avatar
BltByKrmn
Do you guys have problems with your chin spoiler scraping?
Old May 23, 2006 | 09:28 PM
USA1 427's Avatar
USA1 427
Damn. I wish I could lower mine. Yours all look awesome. But where I live, I wouldn't have any fiberglass left on the bottom. Keep the pics coming!
Old May 23, 2006 | 10:55 PM
jrose7004's Avatar
jrose7004
The kit comes with the car!
Old May 23, 2006 | 11:05 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Did the same thing and like the looks much better.
Old May 24, 2006 | 12:36 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Almost, but... the front lowering bolts get turned counter-clockwise to lower. I just did it this past weekend.
Old May 24, 2006 | 12:54 AM
IDM's Avatar
IDM
Thought it was tighten all the way for the fronts and undo the rears so it would be clockwise for the front and counter for the rears
Old May 24, 2006 | 08:57 AM
c54dan's Avatar
c54dan
Based on this writeup since I have the F45, does lowering (safely) 1/2" front and rear justify paying for another alignment?
Old May 24, 2006 | 09:23 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
It is... except you are turning the front bolt by the tip (not the head), so you tighten it by turning ccw. There is a square tip on the bolt that accepts a 10mm wrench, so you must turn it counter-clockwise to lower. Like I said, I just did this last weekend. I think I'd notice if my car was higher.
This page explains it pretty well, except it incorrectly refers to the front lowering bolt as "reverse threaded". It's not reverse threaded, you are turning it in the opposite direction from expected because you are turning it from the tip (see below).
To my c5 needs lowered!!!
