DRL...not the usual problem
Old May 23, 2006 | 05:39 PM
99pewtercoupe's Avatar
99pewtercoupe
Default DRL...not the usual problem
I noticed my right DRL wasn't working so I went to change the bulb. When I pulled the bulb it did not look burned out but I put a new bulb in anyway. Before I buttoned things up, I started the engine and the bulb lit up. I get the whole thing buttoned up and back the car off the ramps and then see the DRL is not working again.
Any suggestions?
Old May 23, 2006 | 07:54 PM
DeeGee's Avatar
DeeGee
Could it be a bad connection in the lamp socket?
I'd pull it out again and see if a good wiggle on each wire causes it to go out. Off the top of my head the brown is the DRL wire with a common ground with the T/S.
Old May 23, 2006 | 11:12 PM
Cole's Avatar
Cole
Any suggestions?
I found a problem in the connectors leading to the headlights. Groundinng is also a likely culprit.
Old May 23, 2006 | 11:46 PM
jrose7004's Avatar
jrose7004
The same thing happened to me and somehow the bulb had fallen out.
To DRL...not the usual problem
