Brake Fluid Flush
Old May 24, 2006 | 11:11 PM
jah13's Avatar
jah13
Default Brake Fluid Flush
I own a 1998 C5 with 18K original highway Miles. Do I need to change the Brake fluid given the age of the car?
Old May 24, 2006 | 11:16 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
18K of road racing miles? or highway miles?
Old May 24, 2006 | 11:32 PM
jah13's Avatar
jah13
..Highway miles..
Old May 24, 2006 | 11:35 PM
99C5Vert's Avatar
99C5Vert
It won't hurt to change it, but since you only have 18K on it in 10 years, i'd say drive it a little more
If you do change, buy some speed bleeders (http://www.speedbleeder.com).
I changed mine (99 vette, 58000 miles at the time), and changed my bleed screws... easy one man job to bleed the brakes.
Old May 25, 2006 | 12:12 AM
Lancer033's Avatar
Lancer033
yes, DOT 3 brake fluid should be changed every 2 years, DOT 4 should be changed every year.
you're way over due. Brake fluid is designed to absorb water from the brake system. once it is saturated, any water that gets into the system pools and can cause rust.
To Brake Fluid Flush
