[Z06] Clutch Recommendations? Need info fast!
Old May 24, 2006 | 11:39 PM
chad4msu's Avatar
chad4msu
Default Clutch Recommendations? Need info fast!
Ok the dealer has my car fixing a transmission issue. While they have it open, I'm seriously considering getting a new clutch.
Here's what I am about to install on my stock '02 Z06:
Full exhaust
CAI
Cam 224/224
150 wet shot
fuel pump (if necessary)
Hardened Output shaft
Tune
I'll be using M/T DR's.
What clutch are you guys using for similar setups? I don't plan on modding it further.
Any info would be GREATLY appreciated.
Old May 25, 2006 | 07:30 AM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I have a friend who installed the LS7 clutch late last year, he has had it to the track 2 times now (Cammed/Bolt on Z06) running low 11's with 60' times in the 1.6x's..... no issues with slipping/soft pedal with hot lapping the car.
Not sure how it would be with another 150 hp and probably 200+ torque from the nitrous, if you want to be really safe I would go with the RPS or Textrallia set up. Both are quite pricey though
Good Luck on your decision
Old May 25, 2006 | 09:45 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I'm very pleased with my Textrallia "Aussie" clutch so far!...
Old May 25, 2006 | 10:26 PM
chad4msu's Avatar
chad4msu
cool. thanks for the info!
What are the odds that the Texrallia one will grenade my tranny like some Spec 3's I've read about?
I'm not planning on spraying all the time... (just when I need it... hehe)
But I'm looking for a clutch that can definitely handle the power and still last me at least a couple of years with only a moderate amount of "spirited driving"...
Old May 29, 2006 | 10:15 AM
ace67's Avatar
ace67
Mcloud twin with lightend flywheel , i have a similiar setup.
Old May 29, 2006 | 10:56 AM
Ranger's Avatar
Ranger
A thread to read...from LS1tech....
Corvette Guys Beware
Ranger
Old May 29, 2006 | 12:57 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
Same here. Dropped .12 off my short time with it. Holds up awesome and never fades or gets hot. I would wrap the lines (that helps) and go to a higher temp fluid. O yea, if you run it alot and will need to bleed it often, you might want to install a remote bleeder while you are at it. Good luck and +2 for the aussie.
Dave
To Clutch Recommendations? Need info fast!
