Show Prep....engine compartment
Old May 25, 2006 | 12:09 AM
fixit5355's Avatar
fixit5355
Default Show Prep....engine compartment
Getting ready for an up comming judged show.I have the ext & int. spotless. What do you use to get the engine compartment spotless? The wiring,frame and firewall are sandy,dusty and just not the way I want them to look.......any idea's
Old May 25, 2006 | 12:19 AM
masksqueeze's Avatar
masksqueeze
I use rags and glass cleaner beleive it or not.... works for me.
Old May 25, 2006 | 01:08 AM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
I use a compressor to blow out all the dust I can, then I wipe down
everything I can reach with a damp cloth. Then I apply the hoses with
303 Aerospace protectant. It gives a nice sheen to them without over
doing it. Takes a little time but well worth it.
Old May 25, 2006 | 01:11 AM
slammedwhitec5vert's Avatar
slammedwhitec5vert
I rinse with low pressure every time I wash the car and wipe everything dry and use windex on the chrome..
Old May 25, 2006 | 01:58 AM
GrayC5's Avatar
GrayC5
The Car Care Discussion section of the forum is the best place to go for answers to these type questions. Several very knowledgeable people and a few professional detailers hang out there.
Sticky thread at the top of C5 General: Questions about CAR CARE: wax, window cleaners, etc...
Good luck!
Old May 25, 2006 | 02:02 AM
Swany00's Avatar
Swany00
Veteran: Marine Corps
Gunk, make sure you grab a tree hugger so they can watch ya!
I use window cleaner and a bunch of towels (elbow grease)
Old May 25, 2006 | 06:42 AM
For my engine compartment, I use an old Absorber and wipe down everything I can get to. If there is a lot of dust, an air compressor works well to blow the stuff off. If there is some grease/oil, I use a rag with Simple Green. To finish the job, I use a product called In and Out Detail Spray - available from Adam's Polishes. Works great on hoses and wiring looms.
Old May 25, 2006 | 06:56 AM
Z0SLIK's Avatar
Z0SLIK
Old May 25, 2006 | 08:52 AM
ALLEGRO's Avatar
ALLEGRO
As a disclaimer my car is never driven in the rain so this job for me is a bit easier. I did however win 1st place in the Stock Coupe division of the Beale Street Corvette Show in Memphis in April.
Dependant on how dirty it actually is here is what I do:
Use compressed air or even your shopvac on exhaust to blw away anything you can. This works well for the areas you just can't get to with a rag.
I then use a series of paint brushes to brush away what is left. I put tape around the metal area of the brushes so that they do not scratch or make things worse. This will take some time....be methodical.
I then wipe down with some Quick Detailer the entire compartment. This stuff will remove all the earlier detailer and leave it really clean.
Now for the shine, I spray liberal amounts of Armour All on the engine, hoses and plastic. Then I start the car and let it warm up all these parts. Then shut it off and let it cool. This will leave a simi-gloss shine that appears to be new/stock and will last for a good amount of time.
Try it.
Old May 25, 2006 | 09:24 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I always use Simple Green for the initial cleaning of the engine compartment if it is very dirty or greasy.
I spray it on a warm engine and let it sit for a few minutes, then lightly mist it off with a water hose. I'm also always careful around the alternator, usually covering it with plastic or foil.
After the engine compartment is clean, then it's a simple matter, everytime I wash the car, of misting it down with water , using a leaf blower to get all the crevises dry, and wiping down with a quality microfiber towel to keep it looking good...
To Show Prep....engine compartment
