CCW and big brake kit problems.
Old May 27, 2006 | 02:47 AM
Bret01Z06's Avatar
Bret01Z06
Default CCW and big brake kit problems.
Well I ordered a set of CCW 19X10/19X11 SP500’s today. A few hours later John called to inform me that the standard 2’F/3’R lips wont clear a monoblock caliper. I was planning on a C6 Z06 brake setup, but it can’t be done with the 2’/3’ lip combo. It can be done, but I have to go with a 1’/2’ lip combo. I wanted the bigger lips and the big brakes, looks like I can’t have my cake and eat it too. Anyone run into this same problem? I have to give an answer to John ASAP on which I want so he can start on the wheels.
Thanks,
Bret
Old May 27, 2006 | 01:04 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
Yep, that's pretty much standard.
BUT, if you can make it work with the smaller lip...........
Otherwise,using a spacer may help some,but I am unsure if it would yield enough room.
Besides, your wheel would stick out some then.....
Old May 27, 2006 | 01:23 PM
Bret01Z06's Avatar
Bret01Z06
John himself said it will work with the smaller lip. But I want the biggers lips. LOL
Old May 27, 2006 | 02:03 PM
AU N EGL's Avatar
AU N EGL
Only the CCW Motorsports wheels work with a BBK unless you use longer studs and and a 1/4" to 3/8" spacer
Old May 27, 2006 | 02:22 PM
Bret01Z06's Avatar
Bret01Z06
Yeah. Hmm Bigger lips or bigger brakes?
Old May 27, 2006 | 02:25 PM
tiojames's Avatar
tiojames
Default big brakes
You can use the hardened spacers and chrome moly lug studs from DRM and use your wheels and the C6Z06 brakes. I just finished using this set up on mine.
Old May 27, 2006 | 02:45 PM
Bret01Z06's Avatar
Bret01Z06
Just called John and ordered the Big Lips and I will get the C6 Z51 rotors and brackets later on.
Old May 27, 2006 | 03:45 PM
yellow01's Avatar
yellow01
well if you insist on those Angelina Jolie wheels you're gonna need spacers!
Old May 27, 2006 | 08:27 PM
Bret01Z06's Avatar
Bret01Z06
No spacers needed.
Old May 27, 2006 | 09:31 PM
yellow01's Avatar
yellow01
Originally Posted by Bret01Z06
No spacers needed.
Meant the big lips with the BBK. just joking.
Old May 28, 2006 | 10:05 AM
Darion's Avatar
Darion
Man, John at CCW doesn't miss a thing. Great service, can't tell ya how many times I have read about wheels being ordered just to find out they don't fit. Nice wheel choice, I'll be putting in an order in a month with CCW, can't wait.
Darion
Old May 29, 2006 | 12:36 AM
Bret01Z06's Avatar
Bret01Z06
Darion
John is the man. I cant wait to get my wheels.
To CCW and big brake kit problems.
