Column Lock
Old May 27, 2006 | 10:37 PM
11yellowgscpe's Avatar
11yellowgscpe
Default Column Lock
I recently bought a 1999 Coupe. Is there a way to tell if it has had the steering column lockout kit installed?
Old May 27, 2006 | 10:39 PM
BAD AZZ C5's Avatar
BAD AZZ C5
St. Jude Donor '06
Pull out your key and turn the steering wheel and see if your column does LOCK!!
Old May 28, 2006 | 12:32 AM
If you can turn the wheels with the ignition off, then the column lock has been disabled.
Old May 30, 2006 | 08:12 PM
11yellowgscpe
Took a while to get back but thanks to the vetters that responded.
To Column Lock
