Blackwing and water
Old Jun 1, 2006 | 09:05 AM
hotrod03's Avatar
hotrod03
Default Blackwing and water
Just installed a Blackwing and noticed where the filter is located in regards to the hood when raised. It looks to me that if you had water on the hood, and raised the hood, the water would drain right into the filter. Has anyone noticed this?
Old Jun 1, 2006 | 09:55 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Yes, I have the halltech stinger intake, and the filter sits in the same spot also and is open like the Blackwing... I have had this happen before and just take towel and lightly dab it off...or just let the car sit for a while til it dries....so long as there is not a huge puddle of watter or it does not get sprayed direclty with the hose, you'll be fine.
Old Jun 1, 2006 | 10:08 AM
sailohio's Avatar
sailohio
It's not a big issue. Don't worry about it.
Old Jun 1, 2006 | 10:38 AM
dukekid68's Avatar
dukekid68
If it's new it should be oiled and the water will run right off it
Old Jun 1, 2006 | 12:52 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
when I wash my engine the blackwing does get wet, but there have never been any problems.
Old Jun 1, 2006 | 02:13 PM
BAD AZZ C5's Avatar
BAD AZZ C5
St. Jude Donor '06
This should not be an issue!
Old Jun 1, 2006 | 02:15 PM
C6NRED's Avatar
C6NRED
Default hood seal?
I've got the Halltech too....no problems with water so far, open or shut. However, one thing IMHO you may consider is the aftermarket hood seal (Eckler's sells one....) that runs along under the front edge of the hood. This at least seals it up over the filter with the hood closed..........they also claim that it better forces air through where the filter is located....don't know about that claim
Old Jun 1, 2006 | 02:34 PM
Z0SLIK's Avatar
Z0SLIK
Old Jun 1, 2006 | 03:45 PM
IrishJoker's Avatar
IrishJoker
Not a problem since this is not a paper filter - have you actually laid hands on it?
Mine has been on for two years and I'm not careful or concerned about it getting wet - if that was an issue it would have been an enclosed type and not an open type. I would get that front hood seal though.
Old Jun 1, 2006 | 07:30 PM
hotrod03's Avatar
hotrod03
Thanks everyone for their input!
Old Jun 1, 2006 | 07:54 PM
Steveo1c5's Avatar
Steveo1c5
Yes But I fixed that problem and now I don't get a drop of water on my Blackwing, and No I don't use a hood seal.
Old Jun 1, 2006 | 09:17 PM
RPOZ4Z's Avatar
RPOZ4Z
don't waste your money on a hood seal, it's just cosmetic.
Old Jun 2, 2006 | 12:19 AM
Thee Hwyman's Avatar
Thee Hwyman
Where can I get the blackwing "cleaning & oiling" kit?
Old Jun 2, 2006 | 09:14 AM
jrose7004's Avatar
jrose7004
Just use Simple Green and a soft brush to clean it and use a mixture of mineral oil and alcohol in a spray bottle to recharge it!
Old Jun 2, 2006 | 11:46 AM
IrishJoker's Avatar
IrishJoker
From here: http://www.corvettegarage.com/produc...aning-kit.html
To Blackwing and water
