Can Anyone Help!!!!!!
Old Jun 3, 2006 | 03:06 AM
bigmark's Avatar
bigmark
Default Can Anyone Help!!!!!!
Hi there, hope all is well...
In my 1998 automatic c5 corvette, i hit the driverside rear end on the center divide, it snapped the spindle in half and bent the arm and ripped of the side fender... Well thats not the problem
When i go to start the car, i go to turn it on and a loud sound comes from the rear end somewhere, not just that but the back of the car jumps up a little bit, i cant figure it out, does anyone have any advice,
thanks and God Bless,,,
Old Jun 3, 2006 | 03:24 AM
bigmark's Avatar
bigmark
Old Jun 3, 2006 | 03:32 AM
01QuickSilver's Avatar
01QuickSilver
Possibly the electric fuel pump has been damaged or "repositioned", and is now making contact with the fuel tank. Turning the key on sends power to the pump - and most likely is the source of your noise. Not sure what to say about "the back of the car jumping up a little bit"...
Hope things work out for ya
Old Jun 3, 2006 | 05:48 AM
JCR's Avatar
JCR
You need to rebuild the whole *** end. You have a bent axle among an array of additional problems back there.
Old Jun 3, 2006 | 07:48 AM
Mongolink's Avatar
Mongolink
[QUOTE=bigmark] Hi there, hope all is well...
THAT SOUNDS LIKE A PROBLEM TO ME!!!
LETS REVIEW, SNAPPED SPINDLE,BENTARM,NO FENDER!
AND YOUR WORRIED ABOUT A FUEL PUMP NOISE!!!
I'D BE PUKEIN!!! tAKE IT TO THE SHOP AND GET IT FIXED!!!!!!!!!!!!
JMO
Old Jun 3, 2006 | 07:50 AM
Oldvetter's Avatar
Oldvetter
It is your ABS Brakes. The pump is located in the rear on early C5s.
You posted this same post back in 3/23/2006, did you not believe the answer then ?
Old Jun 3, 2006 | 07:53 AM
BAD AZZ C5's Avatar
BAD AZZ C5
St. Jude Donor '06
How the Hell did this happen! What were you thinking! THIs sounds like major damage. Hope it is not to expensive of a repair! Be Careful next time!
Old Jun 3, 2006 | 08:27 AM
Dark-Knight's Avatar
Dark-Knight
Sounds like a big deal, big repairs are likely needed. Hope it turns out to be less that we all think it may be.
Good luck!
Steveo1c5's Avatar
Steveo1c5
You posted this back on 3/23/06 what gives? in 2 months you haven't repaired your vette or put it in a shop? I don't get it.
To Can Anyone Help!!!!!!
