Window Valet Question
Old Jun 7, 2006 | 09:42 AM
jashearer's Avatar
jashearer
Default Window Valet Question
So when I bought my Vette, '00 Coupe, I found a window valet in the rear passenger side storage compartment.
I did some research on it, and plugged it in this weekend. Its nice to be able to have the radio on and the windows down when I approach the car, but when I try to raise them they get to the top and then come back down.
After reading their website it seems as though its sensing an obstruction and the safety feature is bringing it back down. I know you can change the pressure sensitivity, but I need a PIN in order to do this correct?
I don't have any documentation with the valet, so can I just call Topdown Tech?
Thanks!
Jay
Old Jun 7, 2006 | 09:45 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I would think so - they are nice folks, and they will have a solution for your problem I'd hope. All it's going to cost you is a phone call.....
Old Jun 7, 2006 | 10:05 AM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
Thanks!
Jay
I believe the PIN in on the window valet itself, you will need to reprogram it again to stop the up/down window situation. Here's a tip- keep your windows down for about an hour before reprogramming the valet, it'll allow the seals on the targa to form back to its shape and not get hung up and trip the valet's sensor! good luck!
Old Jun 7, 2006 | 10:09 AM
barrynk's Avatar
barrynk
I found the window valet manual here : http://www.topdowntech.com/documents/WV-100.pdf
You probably need to calibrate the device for your car - see sections 14&15 of the manual. The PIN should be the last four digits of the device's serial number.
Old Jun 7, 2006 | 10:36 AM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
Right on point.
Old Jun 7, 2006 | 12:20 PM
pfp972's Avatar
pfp972
I have a 2000 also and had the same problem when I first got my window valet. I reprogramed it a few times and have not had the problem since.
Old Jun 7, 2006 | 01:16 PM
napacruzerc5's Avatar
napacruzerc5
Be sure the doors are closed when you do the re-program. Don't program with the doors open since the valet won't sense when to stop.
Old Jun 7, 2006 | 01:23 PM
gr8corvette's Avatar
gr8corvette
Gr8Corvette
The problem might be that your windows were not both at the same position before using window valet. My experience has been that if one window reaches the top before the other one, both will go back down. I have always assumed this was a safety thing to prevent someone from losing their fingers, i.e., it assumes that something is blocking the window at the top because the other one is still closing.
Old Jun 7, 2006 | 10:25 PM
jashearer's Avatar
jashearer
Thanks for all the advise everyone!
I shot an e-mail to their support line, and the came back with the same info Barry had mentioned.
Great customer service (from the President of the company no less), and the guy even threw in a story about how his family were John Deere folks (I work for Deere).
Thanks again for all the replies. I'll give it a shot tomorrow and cross your fingers for me, because it does seem like the passenger side rolls up slightly faster than the drivers side
Jay
Old Jun 8, 2006 | 11:41 AM
jashearer's Avatar
jashearer
Ran through the summary process he sent me and now it works like a charm.
Nice little mod at no extra dollar spent for me. I'm a big fan!
Jay
To Window Valet Question
