[Z06] launch
Old Jun 9, 2006 | 12:26 AM
silver_z06's Avatar
silver_z06
Default launch
I just install a new centerforce dual friction clutch with an alluminum flywheel on my 02 Z06 I already have the raptor xxl cai and mickey's et slicks, what RPM range should I launch to be safe
Old Jun 9, 2006 | 06:10 AM
Ranger's Avatar
Ranger
Might want to take a read through the write up on Z06 launch techniques in my signature. It's a place to start.
The clutch you've chosen will bite hard and it will be less inclined to support a small amount of slip.
Have you hardened up the rear end?
Are the MTs the radial or bias-ply version?
Ranger
Old Jun 9, 2006 | 05:07 PM
robz's Avatar
robz
As Ranger has mentioned, we need more info. If you had a guarantee that your car wouldn't break something, you could probably launch off the limiter on a stock car with et streets/drags. Alot depends of rwhp,tire size,temp,prep, etc. If you have mt etstreets and 370 rwhp you might want to keep them aired up(22 psi-24psi) for starters and see how the car reacts. You don't want bog. Give us more details and we can guide you better.
Strong clutch/high launch + Mt slicks = increased chance of breakage.
Old Jun 11, 2006 | 02:50 PM
silver_z06's Avatar
silver_z06
I have the et streets slicks and my rear end is completely stock nothing done to it
Old Jun 11, 2006 | 03:29 PM
Ranger's Avatar
Ranger
You have a risky combo. As robz said, the stronger clamping force of the aftermarket clutch will accentuate the hook-shock of the ET Street bias-ply tires and thereby transfer a greater shock to the rear end.
You may be OK. You may break the rear. QuickSilver ran 11.40 with your combo except Nitto DRs, at least for a few passes and then disappeared. So not sure if he eventually broke the rear.
So it's a crap shoot without hardened shafts in the rear.
I'd suggest starting at 4K and see that happen. But a dead hook is the biggest risk. You want to avoid that.
Robz may have more light to shed.
Ranger
Old Jun 11, 2006 | 08:56 PM
CHRIS DANIEL's Avatar
CHRIS DANIEL
Default blown o6 z06
Ranger
Broke the right side and rearend mount on the right side on DRs.first pass went easy left @2500 kill the motor 8.05,2 pass left @ 3500 and bog the motor miss 3rd 7.53 @92mph,3rd pass left @4000 felt good shifted @6800 and broke.(06 z F-1 made 689hp with 4.50 pulley,893hp with 4.38)
Old Jun 11, 2006 | 10:50 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
I was able to get 150+ runs in before the dreaded dead hook and left shaft breakage. I had a DTE strut and a Aussie clutch with 315 DFG drs. Launch rpm for me was average 4500/5500, and the one that broke me was a 5600rpm. Now hardened shaft is going in. You may last a while, then again could go right away. I am also moving to the ET Street, as from what I hear they may be able to absorb some of the intial shock that a dr cannot which will/may save some breakage woes. Then again they stick mucho better?
Robert
Old Jun 13, 2006 | 02:39 AM
silver_z06's Avatar
silver_z06
how do I reinforce my rear end, how do I harden it
Old Jun 14, 2006 | 12:22 AM
Robert56@RNS
Collections Hold
Get a hold of Rodney at RPM Trans. Check in the sponsor adds under trannys. He has all the goodies.
Robert
Old Jun 14, 2006 | 08:37 PM
silver_z06's Avatar
silver_z06
thanx for your info
To launch
